Old 03-14-2020, 03:52 AM   #7
Starter986
1998 Boxster Silver/Red
Originally Posted by flouese View Post
I get the cheap part, easy, not so much. Mine has loctite on it. Dug most of that out. My problem is that I can’t get a screwdriver in there and be able to put enough torque on it to get the set screw to turn going to search for a 90degree small screw driver and see if that helps. Any suggestions on a better plan?
Did you remove the air vent... going in from the side instead of from under?
1998 Porsche Boxster
Starter986 is online now   Reply With Quote
