Old 09-06-2019, 11:23 AM   #1
2 piece rims
Kinda new at owning a 986 with two piece rims. Question is does the rim have to come apart to have new tires installed. From what I can tell, the two piece is a inner piece that mounts to the entire outer rim. Not like a Hummer where the two halves ( sorta) mount together. Just trying to figure out if my usual shop can do the work or do I need to find a indy Porsche shop.
SMK Shoe is offline   Reply With Quote
Old 09-06-2019, 11:34 AM   #2
Who's askin'?
maytag's Avatar
I've never seen two peice rims on a 986.
Old 09-06-2019, 11:54 AM   #3
I'll go take a pic and post it. almost looks like it has bead lock for a lifted four wheeler
Old 09-06-2019, 12:08 PM   #4
pic of rim and car. Not even sure if they are original to the 2000 986
absolutely no idea how to rotate. Atleast I got the size pretty good.
Old 09-06-2019, 12:18 PM   #5
M2
2 piece rim
I have rims that are similar and I believe they are only aesthetic in nature not actually a 2 piece rim???
mcmike27A is offline   Reply With Quote
Old 09-06-2019, 12:19 PM   #6
BYprodriver's Avatar
No you just need a good tire mounter with decent equipment. Those are optional wheels made for Porsche by BBS. Just make sure you have no air leaks now. That stainless steel band around the rim can be removed & replaced or repaired if it gets dented.
I assume the Hummer has split rims which is 2 halves joined together like a 18 wheeler truck.
Old 09-06-2019, 12:24 PM   #7
They are factory two piece BBS wheels, cost about $550 each:
Old 09-06-2019, 02:48 PM   #8
edc
550 Anniversary
edc's Avatar
The 17" version is a single piece wheel. The 18" ones are made by BBS and called Sport Classic II.
Old 09-06-2019, 06:03 PM   #9
The 18" Sport Classic wheels by BBS were an option on the 986 and 996. I had a set on my 996. They are really nice looking but a complete PITA to clean (lots of little nooks and crevices).
You never take them apart unless there is a problem. There is no maintenance. New tire installation, mounting, and balancing is done normally just like any single piece wheel.
Old 09-06-2019, 07:39 PM   #10
Porsche "Purist"
Paul's Avatar
1987 924S. 2002 996TT. PST-2
Old 09-07-2019, 04:08 AM   #11
Paul, when I say you pic the first thing I thought was looks like Wis. I was born and raised in lower Wis and visit family often. But military service kept me in the Carolina's and stayed after I retired.
Old 09-07-2019, 10:09 AM   #12
Who's askin'?
maytag's Avatar
Originally Posted by Paul View Post
Yeah, I'm learning something new.
I've seen a set of those that were clearly cosmetic only, not a true 2-pc.
Looks like, reading below, the 17's were cosmetic, where the 18's were true 2-pc.
And there we are.
Old 09-07-2019, 12:51 PM   #13
edc
550 Anniversary
edc's Avatar
The 17" version of the split Sport Design and Sport Classic are not cosmetic as such. They don't have fake bolts. They are simply a single piece wheel with the same wheel face design.
Old 09-07-2019, 02:29 PM   #14
Who's askin'?
maytag's Avatar
What purpose do those bolts serve?
Old 09-07-2019, 02:52 PM   #15
1998 Boxster Silver/Red
Cool factor.
1998 Porsche Boxster
Old 09-07-2019, 03:11 PM   #16
edc
550 Anniversary
edc's Avatar
Erm they bolt the 2 pieces of the wheel together.
Old 09-07-2019, 03:15 PM   #17
Who's askin'?
maytag's Avatar
Then why did you say this:
"The 17" version of the split Sport Design and Sport Classic are not cosmetic as such. They don't have fake bolts. They are simply a single piece wheel with the same wheel face design."
Are the 17's 2-pc or not? (The ones I've seen are not). And if they are NOT, then what purpose do the bolts serve? "Cool", as starter986 said. Which makes them merely cosmetic, as I said.
Right?
What am I missing here?
Old 09-07-2019, 03:20 PM   #18
edc
550 Anniversary
edc's Avatar
The 17" version has no bolts real or fake. They are a single piece wheel. The 18" ones have proper bolts.
Old 09-07-2019, 04:55 PM   #19
Who's askin'?
maytag's Avatar
Nah, the ones I was looking at had bolts around 'em. But definitely a 1pc wheel.
Old 09-08-2019, 01:02 AM   #20
edc
550 Anniversary
edc's Avatar
Sounds like they were aftermarket wheels then.
