12-19-2018, 04:59 AM
Brake gas pedal
Does anyone know a vendor that sells the medal covers for the gas,brake and deadfot pedals. I looked on eBay and they are all from China. I really want something nice
12-19-2018, 05:57 AM
1998 Boxster Silver/Red
Do a search for metal covers and you may have some luck.
1998 Porsche Boxster
12-19-2018, 07:00 AM
Brian from SRP Racing in NC makes them, I have got his throttle pedal cover (have had 2 actually, I started with the one that has 2 bumpouts for heel toe, and then went to the one that was a little wider but no bumpouts), and I just bought a pair of brake and clutch covers from them:
https://www.srpracing.com/pd-986-boxster-1996-2004-porsche-racing-pedals.cfm
Edit: here is a picture of them from Woody's build thread - these are the same style as the ones I recently bought.
https://986forum.com/forums/481406-post91.html
12-19-2018, 07:11 AM
Pelican has 20% off Rennline right now and if they don't have the pedals in their discount Rennline dot com has 15% off everything through this Friday.
12-19-2018, 07:20 AM
thanks How hard are these to install, it looks like drilling some holes in the original edals. is this hard to do Thanks Jimbo
12-19-2018, 07:26 AM
I did the Rennline gas pedal with the adjustable spacer plate option that goes underneath it and the side tabs last year. They provide a paper template to show you where to drill the holes. It wasn't hard at all. I got it done without any screw-ups. For me I often have a screw up before achieving success so I would say it was pretty easy. The brake and clutch pedals are metal so drilling them is probably a bit tougher, I only wanted to make my gas pedal more adjustable to try heel and toe.
12-19-2018, 09:24 AM
12-19-2018, 11:41 AM
I did the China thing as I really wanted the look, not for racing. They were a pleasant surprise for the $$$. I also bought with rubber inserts.
You don't have clutch pedal so easier as making sure the clutch and brake pedals lined up. I bought some different bolts to install as I thought they should be. I also used wood working hand clamps to hold the clutch/brake pedal in their locations as I drilled
Seal Grey
12-19-2018, 03:41 PM
FVD Brombacher has them too. I remember seeing them while browsing there catalog.
12-19-2018, 06:21 PM
Sorry about the double post. Fixed now.
Reason: double post
12-20-2018, 08:24 AM
Do you install these right over the gas and dead pedal and then remove the brake pedal rubber if not how do you install these.thanks Jimbo
12-20-2018, 08:38 AM
Yes you install on top of existing dead foot and gas pedals, remove rubber from brake & clutch and install.
Seal Grey
12-20-2018, 09:34 AM
I can't remember whether I had to drill three holes in the OE dead pedal, or whether I removed the OE screw from the OE dead pedal, and was able to line up the upper hole in the aluminum cover and had to drill only two holes for the short attaching screws. Either way, it's easy work.
Pulled off the OE rubber brake pedal cover, marked metal brake pedal and drilled the three holes needed to attach the aluminum cover. Same process for clutch lever. Rubber OE pedal covers are not reattached.
Attached the aluminum accelerator pedal to the OE pedal with short screws after drilling three holes.
I forgot to mention that the necessary fasteners weren't included by my Ebay seller, but since I had onhand lots of flathead stainless steel screws and machine screws, and nyloc nuts, I was able to use them.
I'd suggest that if your selected seller doesn't say that the necessary fasteners are included with the kit, that you check with them before you place your order.
Hope this helps.
jD
12-20-2018, 12:31 PM
Thanks everyone
12-21-2018, 09:28 AM
Major tip if not already mentioned (didn't see)...
Start w/ the brake pedal. You'll be tempted to start w/ the clutch pedal since it's easier but don't.
Why?
The brake pedal, being hardened, has clearance restrictions. Start there and then easily line up clutch pedal to match w/o issue. The reverse however is not true  And use a center punch...
Good luck
"Cool Prius!" - Nobody
12-21-2018, 09:57 AM
Any links are leads on these? How much did they set you back?
They're really nice looking
12-21-2018, 12:41 PM
Charles,
I did mine with the same. About $90 if I remember. Ebay I think
12-21-2018, 04:25 PM
I have been looking for these pedals with the Porsche logo and haven’t been able to find them.any help please
