Major tip if not already mentioned (didn't see)...
Start w/ the brake pedal. You'll be tempted to start w/ the clutch pedal since it's easier but don't.
Why?
The brake pedal, being hardened, has clearance restrictions. Start there and then easily line up clutch pedal to match w/o issue. The reverse however is not true
And use a center punch...
Good luck
