Old 11-01-2018, 09:50 AM   #1
IMS bearing question
Dear All,
As mentioned in my introduction earlier, I bought a '99 Boxster with an alleged IMS bearing failure and therefore a need for a replacement engine. I bought the car with an intent to fix the engine. This is where I am at now (the failure was caused by a broken variocam pad that I found in pieces all over the engine):
My question regards to theIMS bearing. This car has 100k miles on it, and the original dual-row bearing does not show any sign of wear (dust cover removed):
Would you guys replace this?
Also, I bumped into this mod using a slotted hex key that diverts the oil flow and gets pressurized oil from the pump to the IMS bearing. Any experience, thoughts about this?
eBay
Thanks!
