Old 08-16-2018, 07:47 PM   #1
Anybody solved lifter tick at cold idle
It seems that my Boxster has a lifter tick when cold at idle. I believe this started after storage this winter. One lifter was hammering pretty good for awhile after initial start-up. I'll probably try something other than 0W40 next oil change but I'm wondering if anybody has ever had this problem and solved it.
__________________________
'58 356A coupe, just a driver
356Guy is offline   Reply With Quote
Old 08-17-2018, 07:00 AM   #2
15w 40 synthetic oil. And a pint of Marvel Mystery Oil. YMMV, but it works for me.
2001 Boxster
2007 Toyota Highlander
Old 08-17-2018, 09:30 AM   #3
I might try the Marvel. I bought a lot of Mobil 0W40 on sale so it would be nice not to have to switch oils.
Old 08-17-2018, 10:12 AM   #4
Amsoil 5W40.
Old 08-17-2018, 11:07 AM   #5
Originally Posted by ekam View Post
Amsoil 5W40.
Did that fix the issue or is that just what you run? I'm not sure I want to pony up for the Amsoil stuff
Old 08-17-2018, 12:54 PM   #6
I had developed a lifter tic several years ago. It started one winter and continued into the summer. It was especially bothersome during the colder months. I finally read a post by Jake Raby saying that he had used MMO and saved "many an engine" so don't knock it. Anyway, did my research and discovered MMO a petroleum based naptha distillate that is essentially a solvent. Obviously, I was hesitant to put it in my engine but decided to try it as the tic was getting worse. I always change my oil at 3,000 miles and use Motul 8100 x-cess 5w-40. So, I drained about 1 quart of oil, put 4 oz in a full gas tank and the remainder in the oil. I ran it for 500 miles and then did an oil change. Amazing, but there was NO ticking sound after the oil change. I repeat this process about every third or fourth oil change and have had no problems at all with ticking reoccurring.
Jgkram is offline   Reply With Quote
Old 08-17-2018, 02:37 PM   #7
Who's askin'?
maytag's Avatar
I've been using this (or other variations of it to include ATF or diesel fuel) for decades to solve issues, including sticky lifters. It's a great "last ditch" effort, haha. It's not the first thing I do.... because I'm very aware of the risks. But I've had much success.
Old 08-18-2018, 04:12 AM   #8
Got my 09 used that was ticking pretty loud, did an oil change with Amsoil and the sound went away.
Old 08-18-2018, 05:38 AM   #9
"50 Years of 550 Spyder"
10/10ths's Avatar
Lifter tick...
...is very common on many engines.
Assuming you don't have a REAL problem, lifter tick always comes down to some sort of oil issue. Either the lifter does not "pump up" with oil because it doesn't like the oil formula or viscosity, or the oil passage inside the lifter is gummed up with varnish or has an actual small bit of debris blocking the passage.
The above solutions are very viable.
Marvel Mystery Oil has been around this long because it actually does work in many of these cases.
FWIW, I use the Driven oil Jake Raby recommends and change it every 3,000 miles and I have had no lifter issues.
Good Luck.
Old 08-18-2018, 06:56 AM   #10
seningen's Avatar
Could be some dirt in the lifter -- I had one Boxster that did that and used Seafoam.
Didn't think of MMO or I would have tried that.
Went away after about 2-3min of idle, dumped the oil, and it never came back.
Mike
mike@lonestarrpm.com
Old 08-18-2018, 06:57 AM   #11
Is it a requirement to dump the oil after?
Old 08-18-2018, 07:13 AM   #12
10/10ths's Avatar
Sea Foam...
....also does wonders for clogged fuel injectors and carbs.
I have “fixed” many a “broken” motorcycle with Sea Foam.
Old 08-18-2018, 09:53 AM   #13
I found some MMO which seems to be rare around here. Canadian Tire just got it. It wasn't even on the shelf yet. The instructions said to use the whole bottle based on the Boxster sump capacity but I just dumped in half a container. I let it idle and the ticking went away after 5 minutes. The test will be when I start it cold the next time.
Old 08-20-2018, 04:38 AM   #14
Well no luck. The cold start ticking is still there.
Old 08-20-2018, 06:17 AM   #15
Racer Boy
Racer Boy's Avatar
Try putting the recommended amount of MMO in, and give it some miles to work.
Old 08-20-2018, 06:22 AM   #16
You also self admitted you only used half the amount the bottle said to. Add the other half and see how that does for a bit?
Old 08-20-2018, 07:48 AM   #17
Using 1/2 the bottle is like taking 1/2 your prescription medication. Remember this is a lubricant/solvent so it needs time to work. I ran mine for about 500 miles or so after adding and then did the oil change. I'm not saying this will fix your issue but it did take care of mine. I also remember using this stuff wwaaayyyy back when I was a teenager and had an MGB. It worked wonders for the carbs and other moving parts to keep them clean. Good luck...
Old 08-20-2018, 10:13 AM   #18
Guilty although I probably dumped closer to 2/3rd of it in. With all the years of reading posts about fretting over what oil to use it seems like dumping 12 oz of "mystery oil" (ok petroleum distillates and solvents) into an engine is risky business
I put on 5-600 km/week so if it doesn't work over the next week or 2 I'll just dump the oil and replace the lifter.
Old 08-22-2018, 06:48 AM   #19
I hear you. But I have used it in the past with good results and no discernable damage to the engines. Also, when I read Jake's response to similar questions, that kind of sealed the deal for me.
I feel your pain. It's a very frustrating issue and I wish you luck whatever route you take.
Old 08-22-2018, 06:57 AM   #20
... and replace the lifter.
Unfortunately this is the only way to permanently fix it if the solvents aren't helping.
