03-16-2018, 05:01 PM
Trailering wiith a base 986
I have not read any posts of people setting up their Boxster to pull a small travel trailer. I was wondering who is doing this. I presume the exhaust needs rerouting to maybe exit the side to make room for the frame hitch. I would just use the smaller 1” receiver so maybe that will easily fit.? Any comments about people pulling trailers, either utility or small campers would be nice. Thank you
03-16-2018, 05:13 PM
Some people pull little utility trailers with a set of track wheels and tires and maybe a toolbox.
03-16-2018, 05:18 PM
Thank you Mike....I just read of the Willwood Systems designs. Will be looking into this.
03-16-2018, 05:36 PM
No exhaust rerouting necessary. The trailer chains can get hot though  This is me, picture taken yesterday on the way to Carolina Motorsports Park.
03-16-2018, 06:13 PM
I pull a single motorcycle trailer with my 02 Prius. The boxster should be up to the job. Where the black bumper extensions are looks inviting for some sort of custom hitch. Brakes might be a bit scary, but adjusting your driving style can overcome this.
2001 Boxster
2007 Toyota Highlander
10-02-2018, 06:21 PM
Who's askin'?
Hey all:
So, I was looking at building a trailer hitch for my boxster, to tow a tiny little trailer with track wheels, folding canopy, etc.
When I pulled the license plate to have a look, I noticed that the threaded receiver for the tow hook is found dead- center in the bumper.... which begs the question:
How strong is that anchor point?
What if I built a simple attachment that threads in, just like the anchor point, with a trailer ball on it? Would that tow a 400lb load (gross- weight) down the road to the race track?
I mean... that's sure the "easy button". (As opposed to me tearing the bumper off and fabricating something more substantial, as I had intended)
Waddya know?
10-02-2018, 07:39 PM
A friend of mine used to tow that way in his Boxster before he moved to towing the whole car on the trailer. Had a plate welded on to an oem towhook and mounted a ball to that. My trailer hitch mounts to the bumperette points, i don't know if i would do the tow hole method or not, bit he did it. The logic is, if it is strong enough to winch the car up a trailer...
His rig is for sale for $650 in Sarasota fl, Southport trailer and hitch, it is a newer version and nicer than mine
10-02-2018, 10:12 PM
Who's askin'?
Originally Posted by steved0x
..... My trailer hitch mounts to the bumperette points .....
I found yours in another thread: simple, practical, convenient, and looks easy enough to fab-up in an afternoon. I think I'll do that tomorrow, and call it a day.
Do I need to send you a beverage coupon for the rights to use your design? ;-)
10-03-2018, 05:38 AM
No coupon needed, my hitch came with my trailer, i think.it is the southsport hitch. I leave it on all the time
10-03-2018, 08:49 AM
Racer Boy
The OP says he wants to tow a small travel trailer. How heavy is the trailer?
10-03-2018, 09:03 AM
A super light teardrop might work. Keep the weight and windage way down and you should be ok. The Boxster is geared really high so adding too much trailer would strain the clutch or Tip. Maybe something like this: https://golittleguy.com/lg-mypod/
10-03-2018, 09:19 AM
Who's askin'?
I am not the OP.
I jumped into this OLD, but relevant thread, hoping to keep future searches easier.
The trailer I intend to tow is actually made to tow behind a motorcycle. It probably weighs 200lbs-ish, empty, and I'd add another 200#-ish (MAX) in tools, tires/wheels, camp chairs & folding canopy. It looks something like this (but older):
10-03-2018, 10:25 AM
That is a sweet looking trailer, keep in mind, 4 boxster wheels + tires weighs around 200 pounds so it is easy to get up to your max of 400#. I am going to take my trailer up to the dump one of these days and weigh it, and I'll share with the group when I do. When I tow I get 22-23 mph highway and that is the same I get when I drive highway without the trailer, so at least in that way it doesn't seem to affect me that much.
10-03-2018, 10:33 AM
Who's askin'?
Seriously?!?!
I haven't weighed them, so I believe you... but man, I was guessing them around 30lbs/ea. Not 50lbs.
10-03-2018, 12:46 PM
Originally Posted by maytag
Seriously?!?!
I am probably a little wrong  But each one feels like around 50# to me. Let's see:
(Data from Tirerack.com)
Fronts - 225/45/17 Hankook R-S4 - 24 pounds x 2
Rears - 255/40/17 Hankook R-S4 - 26 pounds x 2
100 pounds of tires
OEM Porsche Boxster wheels, I'll use the Boxster S twist:
(Data from 944racing)
Front 17x7 ET 55 - 9.1kg - 20 pounds x 2
Rear 17x8.5 - 10.4kg - 23 pounds x 2
86 pounds of wheels
So ~186 pounds for wheels and tires. I guess other brands and sizes could be different.
That is actually a lot better than 200#, those extra 14 pounds could be tools, canopy, etc...
Dang they are heavy though
