Old 03-12-2018, 05:18 PM   #1
Anyone have pics of replacing the flexible part of the oil fill tube?
In removing my AOS on my 2001 Boxter, I cracked the flexible part of the oil fill tube. how do you access the clamp that holds it to the fill tube in the trunk?
Stiles13 is offline   Reply With Quote
Old 03-13-2018, 03:22 AM   #2
key_lime's Avatar
I found this tricky too - In the end I managed to get at it with a pair of needle nosed mole grips, and a lot of patience
Here's an action shot
If you have a secondary air pump, you will need to remove it - I'm not sure how easy that is, as my car didn't have one
Getting the new hose on was also quite challenging - I used a good quality pair of locking flexible hose clamp pliers to hold the spring clamps open while I located each end, then released. You need to take a lot of care doing this, as the fill tube on the engine side is ridiculously fragile, and will break if you put too much force on it (I broke mine)
key_lime is offline   Reply With Quote
Old 03-13-2018, 09:39 AM   #3
Porsche "Purist"
Paul's Avatar
You could remove the engine wiring harness plug to gain access:
1987 924S. 2002 996TT. PST-2
Old 03-13-2018, 03:58 PM   #4
Thanks! Great info!
Old 03-15-2018, 07:19 AM   #5
Originally Posted by bokepid View Post
artikel bagus
Latvian?
When I replaced my coolant reservoir, I was able to get the clamp by pulling back on the bulkhead pipe manifold and using one of those cable hose clamps. I replaced the rubber hoses as well, and used regular hose clamps on the engine side. (makes it easier to undo the reservoir hoses if they ever need it again.)
2001 Boxster
2007 Toyota Highlander
Old 07-21-2021, 04:10 PM   #6
Originally Posted by Brian in Tucson View Post
Latvian?
FYI moving forward in time. Doing this job now 7 / 2020 . Exact 986 S. PN and it is over half ounce lighter that the OEM take off. Interesting since there is no number change to show a revision. Nice right?
20986 is offline   Reply With Quote
