12-10-2017, 12:51 PM
duke2003boxster
Check engine light 2003 Porsche boxstet
Help!!, My check engine light is illuminating, My put my old scanner on the car and it's not showing any faults. Can anyone provide me a direction i should consider. I first thought I needed to replace the 2 camshaft sensors or the oxygen sensors. I also thought I should consider replacing the AOS. I don't want to just fix other stuff if it doesn't solve my proplem. I'm a DIYer, so I hope someone can help.
12-10-2017, 01:06 PM
Porsche "Purist"
Sounds like a bad scanner. Have an auto parts store check for codes.
1987 924S. 2002 996TT. PST-2
12-10-2017, 02:18 PM
Go to an Autozone or other parts store and have your codes read. No sense in replacing random parts in hopes of fixing it.
12-10-2017, 03:39 PM
Yeah I agree. Also, a failing AOS has other symptoms also, like white smoke on cold starts and abnormal idling...
12-10-2017, 05:55 PM
duke2003boxster
Follow up to vel issue
Okay, DIYers, I used a better scanner and got P0344, which is replace camshaft sensor bank1, finally found where to replace sensor, right front of engine, left sensor left rear of engine, check engine light gone. Thanks for all your help
12-11-2017, 08:06 PM
You found the camshaft sensors where????
Jäger
300K Mile Club
01-10-2018, 01:46 PM
duke2003boxster
Follow up to camshaft sensor issue
I have replaced the 2 camshaft sensors for my 2003 Porsche boxster, however, I still keep getting the CEL light on my dash. Any help regarding what I need to check next would be appreciated.
01-10-2018, 01:57 PM
What code(s) is it throwing?
01-10-2018, 02:55 PM
Sorry for being Capt Obvious, but did you clear the codes after replacing the sensors? The codes don't go away by themselves.
And not sure about everyone else's auto parts stores, but here in Neb they can only check the codes, they can't clear them.  That change has only come in to play in the last yr.
1989 928 S4 5 spd - black
01-10-2018, 03:31 PM
duke2003boxster
Okay update. Used a better scanner and got the P0344 code. Replaced both camshaft position sensors. Cleared the codes, but they keep coming back after a short drive 30 miles or less. therefore, I'm attempting to determine what other issues could be causing this problem. Very frustrating because can't get car smogged without this matter being cleared up. Again thought about oxygen sensors (car has 78K miles, however, haven't gotten any other codes which would indicate sensor issue. Please help
01-10-2018, 03:39 PM
This fault code (P0344) is pretty clear.
P0344 Camshaft position sensor 1 - open circuit
Possible fault cause:
- Camshaft rotor (phase sensor wheel) damaged.
You need to the check camshaft rotor for damage.
01-22-2018, 10:01 AM
duke2003boxster
Okay, DIYer, how difficult is replacing the Camshaft rotor (phase sensor wheel). I'm so frustrated with this issue after changing the camshaft sensor on the right front side (2003) and still getting the CEL light each time I reset it. I can't get the car smogged until I get this matter resolved. I"ve already been quoted an estimate of $800.00 to do this OUCH!!!, Any help from the group would really be appreciated.
01-22-2018, 07:39 PM
Just to clarify, you can't get your car smog tested if there is a CEL light on OR it is giving you the Camshaft rotor error? If so, will your car not pass if you simply take out the CEL bulb (a 15 minute job) from the cluster?
01-22-2018, 09:48 PM
Originally Posted by Porsche-Eh
...you can't get your car smog tested if there is a CEL light on ?
^^ This is correct. ^^
To be more specific, illumination of the CEL light bulb is not what matters; the smog test equipment checks the ECU for emission failure codes and will not pass a car with a code.
01-22-2018, 10:12 PM
Is this your "go-to" solution for CELs? I ask because this is the second time you've offered it as a "solution" in little more than a week. You should not be recommending this to others.
If you're not capable of fixing a car, you should look in to getting a regular mechanic that can.
01-22-2018, 10:33 PM
SO glad we don't have smog BS checks here anymore!
But yeah, disabling the CEL is just stupid. Sorry. It is there for a reason, and with these engines should be paid attention to. To the OP, you will need to get it fixed one way or another.
01-23-2018, 05:08 PM
Hahaha.... removing warning lights IS fixing it  I have a Autel MaxiDiag Elite for when things really do break. Speaking of which, I'll post a new thread for you PW that if I can't fix (code 46) will result in another bulb being pulled  Pretty soon, I think I will have no cluster - might as well remove that too.
OP: Wow, okay. Let's see if we can't get that sorted for you then.
Cheers.
01-23-2018, 05:22 PM
Porsche "Purist"
In WI, the first thing they check is the check engine light by shutting the car off and then turning on the ignition switch.
01-23-2018, 06:10 PM
Cheers.
I hate those idiot lights, they are so frustrating but that much satisfying to turn them off with the right fixes!
I did combat numbers of CEL issues triggered by O2 sensors, MAF, and SEI valves, as well as airbag SRS light issues due to receptacles, corroded terminals and broken clock springs, during my 20-month ownership.
The other day the orange light lit during my morning commute and I was like what's now.... Then realized that it was just a low washer fluid light, whew! Will you kill that light too while you are at taking them out?
01-24-2018, 09:25 AM
duke2003boxster
Okay gang, latest update regarding camshaft sensor issue. I've reordered the Borsch camshaft sensor and will be installing it this evening. In addition, Car will be serviced by Bauer Porsche in Oakland, CA so we can attempt to resolve this matter. Several of you indicated the camshaft rotor might be damaged, but I haven't gotten any word of where it's located and how to repair it. Any help would be appreciated.
