Old 10-20-2017, 12:55 PM   #1
mikesz's Avatar
Has anyone rebuilt their rear suspension?
I need to replace my right inner cv joint. While I am at it I want to replace the wheel bearings and all 3 types of bar links in the rear suspension. has anyone done this and willing to answer questions? What tools will I need to replace the wheel bearings? I am not going to spend 500 on the sir tool!
99 Porsche Boxster
Old 10-20-2017, 02:18 PM   #2
Mike,
I replaced the bearings on the four corners of my CS about one year ago and by thinking about it, just got a back pain.. LOL
Since you are removing the driveshafts, you would be able to replace the bearings in site (without removing the hub), I also purchased a fairly complete bearing removing kit from HF for about $100 and it was pretty straight forward job.
However, I learned the hard way that the bearings have a magnetic strip on one side only (underneath the seal), this triggers the ABS sensor, remember to install the magnetic side towards the transmission.
Good luck!
Old 10-20-2017, 04:33 PM   #3
1999 base
Meir's Avatar
I can rent you the SIR tool if you need.
Old 11-26-2017, 08:41 AM   #4
mikesz's Avatar
I have the right rear axle out. Now trying to remove the rear hub so I can get to the wheel bearing. I am trying to do this without disassembly of the e-brake assembly. I have rented a hammer gear puller. Since I don't want to remove ebrake I cannot use a bearing splitter. Is there any way to remove the hub that I am missing? Has anyone used the sliding hammer to remove the rear hub?
99 Porsche Boxster
Old 11-26-2017, 09:58 AM   #5
Yup, that would be me..
It seems like a Flinstone technique but actually works
However, after doing the rear ones I 'voluntered' my oldest son as my back was acting up, but I used a HF bearing tool kit to get the new bearings into the hub..
Hoping that I don't have to do that job anytime soon :-(
Old 02-11-2018, 06:01 AM   #6
mikesz's Avatar
I wound up Using the HF bearing removal tool and pulled out hub with the sliding hammer as Gilles suggested. Meir, Thanks for the offer but I thought the shipping would be a deal breaker.
99 Porsche Boxster
