Old 10-20-2017, 02:18 PM   #2
Gilles
Originally Posted by mikesz View Post
I need to replace my right inner cv joint. While I am at it I want to replace the wheel bearings and all 3 types of bar links in the rear suspension. has anyone done this and willing to answer questions? What tools will I need to replace the wheel bearings? I am not going to spend 500 on the sir tool!
Mike,
I replaced the bearings on the four corners of my CS about one year ago and by thinking about it, just got a back pain.. LOL
Since you are removing the driveshafts, you would be able to replace the bearings in site (without removing the hub), I also purchased a fairly complete bearing removing kit from HF for about $100 and it was pretty straight forward job.
However, I learned the hard way that the bearings have a magnetic strip on one side only (underneath the seal), this triggers the ABS sensor, remember to install the magnetic side towards the transmission.
Good luck!
