Old 09-15-2017, 06:45 AM   #141
p3230's Avatar
Good for you I knew you weren't a quitter after all you have been through.
Originally Posted by robdelorenzo View Post
Replaced the bleeder valve today, filled it with distilled water, burped it, and drove it like I stole it for a bit.
No leaks, no temperature issues.
I may have dodged a bullet here.
Thanks for the help and encouragement.
I'm new to the world of Pcars.
I think the problem is solved.
Tomorrow I'll pour in the unicorn tears.
I LOVE my Boxster.
Frank
p3230 is offline   Reply With Quote
Old 09-15-2017, 05:22 PM   #142
Well, there is one thing still plaguing me.
I have had all of the carpet pulled up from the trunk for a while now.
I filled it with coolant and drove it and am letting it cool down.
All seems well, except that the strange "rag carpet type thing" that goes across the rear of the bulkhead is wet in the lower right corner by the tank. It has not dried up since the meltdown. I think this may mean that there is steam or coolant leaking onto it ever so slightly or it just hasn't dried out yet.
It is pretty thick stuff and maybe it will just take a while to dry out?
It must be so small of an amount leaking that it's not visible.
The tank is dry, the hoses seem dry, but that thing should not be wet. What is that, anyway?
How can I test it to see if it is indeed being leaked on?
When I press down on it, it's wet.
There's been so much water, coolant, overflow, etc in the past week that I can't tell if it's indeed just soaked or is continually getting wetter.
robdelorenzo is offline   Reply With Quote
Old 09-15-2017, 07:16 PM   #143
Porsche "Purist"
Paul's Avatar
At this point I would just drive it and keep an eye on the coolant level. The level will tell you soon enough if you still have a leak.
Or have the system pressure tested.
1987 924S. 2002 996TT. PST-2
Old 09-16-2017, 06:17 AM   #144
Thanks.
I'm going to drive it a lot today and see what's going on.
A pressure test will be next if the levels seem to change.
This place is very helpful.
Thanks.
Old 09-16-2017, 06:55 AM   #145
Wet carpet in these boxers is notorious for never drying. Take some time to insure no moisture is puddling under the seats. There is a very expensive and important computer sitting in the lowest point of the car - under the seats.
"YouTube Certified in Various Specialties"
Old 09-16-2017, 08:28 AM   #146
Thanks. It isn't the carpet though. It's that brownish looking thing that goes across the firewall at the back of the trunk under the computer. All of the wiring harness sits on top of it. I'll shoot a photo of it and see what happens in the next day or two.
Old 09-29-2018, 10:10 AM   #147
To bring this story to a close, two coolant tanks later (I was warned about not getting a Porsche tank after the first one which was not) the problem was solved.
The original tank went bad.
I had an "off-brand" one installed, which has a hairline crack in the seam on the side and sprayed a fine mist of coolant onto that "pad" in the trunk.
I then had a Porsche tank installed (#2) and that problem went away.
Lesson learned - the $100 I saved by not buying The Porsche Tank cost me a lot more than that to have it replaced.
Old 09-29-2018, 10:42 AM   #148
911monty's Avatar
Well since it's been too damn hot for golf or driving the Box (115 deg yesterday) I guess I'm your Huckelberry, if you're interested.
While your temperature sender apparently needs to be changed I think we still need to verify the leak issue. I have attached a few pics since they're far better than words. So to be clear, your leakage looks exactly like the last pic in the thread I attached yesterday? From the same hose? Maybe this is simple but long range troubleshooting and assumptions don't work. You can verify by having someone pour water into this area while you observe it draining out the hose from below.
In this image I am pointing to the drain. As you can see the only sources (normally) are the cap and the purge/bleed valve.
In this image you can see the tank is two pieces bonded together. The forward nipple is the nipple for the drain to the manifold where it passes thru the trunk. If you look closely you can see that this nipple has very little clearance between it and the tank. There is a possibility this seam has failed here from the overpressure and is leaking coolant. If you can with engine running,and coolant leaking, look down into that hole and see if coolant is coming between the seam. As long as the cap and purge assembly are not leaking, then this really is the only point coolant can drain to that hose.
And a lot of time spent chasing tail...this was post #80. Thanks for the closure.
Old 09-29-2018, 10:46 AM   #149
911monty's Avatar
Ok. Good. Is that coolant leaking from the seam?
This was post #84.
Old 02-05-2019, 03:38 PM   #150
Ok-here is my story and my ultimate question-hopefully in a nutshell. I usually consult past posts on this forum when tying to trouble shoot, this is my first quest for actual advice/info/expert opinion
So I had my local guy replace my water pump mid November. It was an obvious diagnosis-turned out it had disentigrated and the blade was pretty much shredded like most impellers in these old gals. Opted to go ahead and replace thermostat at the same time, upgraded that a bit, had some hoses replaced, necessary seals, connectors, etc since we were in there...
I felt comfortable with a few really good engine flushes as we were able to get almost a complete impeller from the pieces-felt that what was left was most likely going to get shredded to bits and given the history...I feel good about it. Anyway-get her back and she is dropping some liquid. After scouring the forum I realize that it might be a pressure issue.
The long and short of it. After my attempts at bleeding and re-bleeding I am first convinced that I still have a leak-probably some additional hosing that needs to be replaced or perhaps a cracked water resevoir. Every 2-3 days, I drop approx. 1/2 a gallon of what appears to be only the distilled water that I am topping off-not coolant...although I feel like I can smell a little bit of coolant after a good drive.
I've been dealing with this, biding my time for the last couple of months-just topping off-making sure that my resoviour is not low-planning to get her back to my guy to trouble shoot the remaining issue.
Very late on Sunday after a less than climatic superbowl-I am heading home and go to top off my water resevoir and accidentally overfill-it's crazy dark and my friend is slow on the draw with the cell phone flash light. Anyway-it's the first time with an over fill since the work has been done. I shrug it off saying-it's going to leak out fairly quickly anyway. Here's the rub-it's now Tuesday night, and NO CHANGE IN WATER LEVEL!!!
What the heck-could that really have been the problem? Could a pressure issue really have resulted in a coolant/water leakage issue of 1/2 gallon per each 2-3 days? Oh and also my engine light HAD come back on about 5 weeks after the work was completed only to go off on it's own about 4 weeks after that ( which was like 2 weeks ago).
Thoughts? PS. Thank you for taking the time to read and hopefully to respond and PPS. I love my Porche!
Austinsweet01 is offline   Reply With Quote
Old 02-06-2019, 06:46 AM   #151
I also had a bleeder valve go bad. It took a while for it to get bad enough to where I could actually see the leakage around the valve. Until that happened, it would spray out a fine mist of coolant under a certain pressure and then stop when the engine was shut off and the pressure dropped. The crack had to get wide enough to be seen in action to find it. Try a pressure test. Auto Zone will loan you a tester if you don't have one.
Old 02-06-2019, 02:58 PM   #152
Thanks robdelorenzo.
I will definately try to tackle the pressure test-I'm intimidated by auto-projects that have more than about 10 steps but the pressure test sounds like something I might be able to brag about having done myself .
I am trying not to be too optomistic-at this point-about the dry spot under my car in case I start seeing evidence of leakage again.
To give an idea of how significant the leaking was-this is what I'd find each day at 5pm. My officeparking spot is on a slight incline which I guess was allowing the liquid to drain from the under-carriage cover...
Old 02-06-2019, 04:26 PM   #153
So here's something you can do that will take a bit of effort but with no real risk.
Your pic looks like it coolant coming from the forward part of the motor but because of the under panel, who knows.
Here's what I'd do. Slide your seats forward and remove the carpet from the firewall. There are great instructions on this site and others on how to remove the carpet. Look for instructions on water pump or alternator removal. Once removed, remove the metal firewall panel. Don't be intimidated, its just some nuts and bolts that are easy to get at. Once the panel is removed, visually locate your water pump. The pump is located down low on the the passenger side of the car.
Start your car and look for signs of a leak. Be patient, it may be very small, even from around a fastener. Water pump bolts only require 7 ft-lbs of torque, which isn't much. Just see if you can locate anything obvious.
Again, this exercise will be helpful, wether you find the source of you leak or not. At the minimum, you'll know how to access the front of the motor, which will allow you to change your own alternator or pulleys or serpentine belt...all easy DYI's that will save you some bucks.
Old 02-06-2019, 10:37 PM   #154
That is a significant leak, and as stated above, once the firewall access is removed (very easy overall) I’m thinking it will be pretty obvious. The primary coolant hoses run straight down the center of the car, it is possible a clamp is loose, or you have a small split or something. Usually, if you have a pressure issue, you would be blowing coolant out of the reservoir overflow which should empty on the right side of the car just in front of the rear wheel. Your leak is someplace toward the front of the engine most likely. If it’s anywhere on the front of the block you will notice it right away. If it’s a hose, you might need to put the thing in the air and pull the underside rear panel (easy as well) and look for the “wet spot”. The thermostat hose can be a little bit of a bugger to fully seat and get the clamp on properly. As it was replaced, I would start there...
Old 02-07-2019, 06:33 AM   #155
The people on here know what they are talking about (myself excluded) listen to their advice, they are here to help. I have to agree that the leak you are experiencing is way more significant than what I had. The drain hose for the coolant tank is found up under the passenger rear tire. You will see a short stubby hose that is open on one end if you remove the tire. It took me a while to figure out that's where the coolant was coming from. With the help from here, I followed the hose up to the small drain hole in the top of the coolant tank. From there, it was either the caps leaking or the bleeder valve. Stick with it, the coolant system only has so many parts, it's sealed and under pressure so finding the source of the leak will become apparent.
