Old 09-29-2018, 09:10 AM   #147
robdelorenzo
To bring this story to a close, two coolant tanks later (I was warned about not getting a Porsche tank after the first one which was not) the problem was solved.
The original tank went bad.
I had an "off-brand" one installed, which has a hairline crack in the seam on the side and sprayed a fine mist of coolant onto that "pad" in the trunk.
I then had a Porsche tank installed (#2) and that problem went away.
Lesson learned - the $100 I saved by not buying The Porsche Tank cost me a lot more than that to have it replaced.
robdelorenzo is offline   Reply With Quote
