Old 11-06-2016, 02:46 PM   #1
How many miles did you get out of your clutch?
I am having my clutch replaced because the pressure plate was going bad. I'm also having the IMS&RMS done while they're in there. I was able to get 46k of life out of it and was wondering when others had theirs done.
BhamBox is offline   Reply With Quote
Old 11-06-2016, 02:47 PM   #2
Clutch life varies widely between driving styles and environment's, some only last 40-50K miles, other go over 200K. There is no fixed distance.
Old 11-06-2016, 03:07 PM   #3
07 Carrera S Cab
Boxtaboy's Avatar
72k and still on original clutch.
Old 11-06-2016, 03:16 PM   #4
kk2002s's Avatar
91k miles on original still with a perfect release point, no slipping. Only reason I think about changing would be to try and save having to replace the flywheel
Seal Grey
Old 11-06-2016, 03:17 PM   #5
Topless's Avatar
96k miles. Both clutch and flywheel were shot. Driving style is the greatest determining factor in clutch wear.
Old 11-06-2016, 03:30 PM   #6
Changed mine at 90K, though it wasn't slipping in the least. Did so because, (1) I wanted to do the IMS bearing, and (2) Jake Raby has been advocating that you don't want to wait too long or the rivets will be chewing into your flywheel, necessitating that it be replaced as well. I got it about right...mine was worn to the point where that was about to start happening. I think I'm not too hard on a clutch, but someone else owned the car for the first 20K miles---I have NO idea how he drove.
The IMSB? Looked/felt perfect. It's a peace of mind thing I guess
Old 11-06-2016, 03:52 PM   #7
Not sure.
I've had my car for 8.5 years and I purchased it with 76K miles. Don't know if one of the PO's ever replaced it. I'm at 132K now and clutch still feels great.
Old 11-06-2016, 05:05 PM   #8
There Is No Substitute.
rick3000's Avatar
About 80k miles.
Old 11-06-2016, 05:12 PM   #9
Ciao's Avatar
Does changing fluid extend the life of the transmission?
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 11-06-2016, 05:22 PM   #10
Yes...........
Old 11-06-2016, 05:36 PM   #11
BIGJake111's Avatar
I'm on 97k, bought the car at 89k. Clutch wasn't included in any of the documented previous Maintanace so to my knowledge clutch is still original.
Old 11-06-2016, 06:07 PM   #12
AZ986S's Avatar
72K miles.
PO most likely kept the left foot on it too much...
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 11-06-2016, 06:24 PM   #13
JayG's Avatar
82k and the throw out bearing went
the DMFW was also done
Old 11-06-2016, 06:36 PM   #14
95K. Throw out bearing failed. DMFW also gone.
Old 11-06-2016, 07:12 PM   #15
1997 Tip, 2018 Macan
rexcramer's Avatar
What's a clutch?
Old 11-06-2016, 07:52 PM   #16
JayG's Avatar
Originally Posted by rexcramer View Post
What's a clutch?
what, you have a wussamatic?
Old 11-07-2016, 03:16 AM   #17
Luckyed
Luckyed's Avatar
73K on original clutch. (as far as as I know)
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
Luckyed is offline   Reply With Quote
Old 11-07-2016, 04:35 AM   #18
Rennzenn
j.fro's Avatar
These are shots of the clutch that came out of my 996 when I had to pull the engine for an intermix issue. This clutch went in @ 76,133 and the engine was pulled @ 126,600ish, so the clutch has almost 50,500 miles on it.
The clutch in my Boxster went 142,xxx before it was dead. Clutch life is defintely related to where you live and how you drive the car.
Rennzenn
Jfro@rennzenn.com
Old 11-07-2016, 06:00 AM   #19
jb92563's Avatar
Hmmmm, J.Fro, that clutch does look nearly new, the wear is not even near the rivet heads yet.
Mine was worn down to the bottom of the grooves before it finally needed replacement. I had put on 20k miles myself at 75K miles and I think the car had its clutch replaced at 35K miles already so 35k-40K is my cars average.
I measured the remaining disk material to be 3/16" on the DMFW side and 1/8" on the transmission side of the clutch before it started slipping during hard acceleration.
I was a little surprised to see that on the new clutch the disk material is only ~ 1/4" thick per side at the start so its lasts a long time.
I think I read that 30k miles under typical hard use is normal but depending on driver techniques and use it could last 2-3 times longer so 30k - 90k miles.
Many drivers let the clutch slip a lot before fully engaging so that wears the clutch faster. I typcally "drop" the clutch and rev match well so there is little slipping and hence less wear.
If you ever smell burned clutch then you need to improve your technique to get longer clutch life.
Even when doing max acceleration standing starts during Auto-X I don't burn the clutch. It just takes practice and good timing to perfect the technique to extend the life of your clutch.
The Boxster is the first of about 6 cars that I have ever had to replace the clutch on within 90,000 miles of driving them.
Check out mine when I replaced it, just 1/16" clear of the rivets and worn to the bottom of the groves, hence there are no groves anymore.
Clutch Replacement
Old 11-07-2016, 06:11 AM   #20
DrCactus's Avatar
93K and still on original clutch
DrCactus
