Old 09-12-2016, 05:27 PM   #1
urban's Avatar
Parts list for engine rebuild
Hi!
After finding some metal debris on my last oil change, I've started rebuilding my engine (97 2.5, 40K miles). I've found that the debris to be from a previous repair, and everything is ok inside the engine.
Where can I get a complete list of all the replacement parts needed to rebuild it?
Here's what I gathered so far:
Piston Ring Set. Code: 99610303302/1
(Shouldn't be reused, right?)
Engine Gasket Set. Code: 98610090500
going to be replaced
Main Crankshaft Bearing Shell Standard.
Looks good, doesn't seem to need replacement.
Water pump
Looks good, but I'm thinking of replacing it
Big End Bearing Shell. Code: 99610312162
Slightly scuffed, going to be replaced
Timing Chain. Code: 99610517157
No usage marks.
Valve Oil Stem Seal. Code: 99610511552
Seals good, not going to be replaced
Chain Guide. Code: 99610517353
Chain Guide. Code: 99610517552
Engine Head Gasket Cylinder 4-6 no. 99610416903
Engine Head Gasket Cylinder 1-3 no. 99610417009
Tensioner Blade U-Shaped Code: 99610516651
I'll post some pics later.
urban is offline   Reply With Quote
