Old 10-04-2016, 02:45 PM   #1
For those who are interested to do a DIY clutch job. This is a general Sachs instructional video that shows some interesting and important things.
Regards, Markus
Old 04-24-2022, 01:57 PM   #2
Regards, Markus
Great video.
At 5:08 they are torquing the clutch on to the flywheel. What are the torque specs for this? Thanks - 2001 Boxster S
Paul Lohman is offline   Reply With Quote
Old 10-04-2016, 07:15 PM   #3
Nice video, Marcus! I've never seen runout adjustment of the clutch disc before like they show. Good idea if the tooling is available (or can be improvised)!
It kind of made me cringe to see an impact wrench being used to thread the transmission-to-engine bolts in, though. I supose when the transmission is dangling, you want something that works quickly. Probably there is little risk of cross-threading.
I wonder why they marked the inner cv joint to drive flange? I doubt the cv joint and transmission output flange would be balanced or otherwise indexed together, so it seems like maintaining the relative "clocking" isn't important. (To me, it seems like lining it up wherever the bolt holes were available should work fine.)
Finally, that's a slick tool they have for locking the flywheel.
Edit: one more thing - why would he loosen and then tighten the transmission fill plug? To make sure there is fluid in there? (But then, as the fluid seemed overflowing, it couldn't have been an accurate fluid level check?) I don't get it.
2001 Boxster
Old 10-05-2016, 07:54 AM   #4
I don't think it's a problem. If you go to workshops and take a look at the real life – they do things with impact wrenches where you can only shake your head. Also there are different kinds of impact wrenches. Big ones and small ones. As far as i saw it on the video they didn't tighten the bolt with the wrench. I think in this situation when you got the gearbox into right place and need to fasten it quickly an power air or electric driven ratchet is a good tool. And to be honest, you're much faster if you use such tools.
I don't think the unbalanced masses are so high that you can get wobble. But when i replaced my axle boots i recognized that the cv joint didn't go in at every position of the axle shaft. Maybe it also depends on the construction of the inner drive flange. I think in general it's a good idea to reassemble things like they were before.
Agree, that's a cool tool.
Think the fluid level depends on the transmission. In a 986 the fluid level would be to high if the car is leveled, the gearbox is cold and there would be coming oil.
I saw this quick open technique in many instructional videos. I think it's mainly to check if oil is in.
Regards, Markus
Old 04-24-2022, 08:31 PM   #5
Thread is kind of old (though still very useful!).....
