Old 07-13-2016, 02:14 PM   #1
Cam Lock Tool for IMS update...Dimensions?
Does anybody have the dimensions for the "Cam Lock" tool for when I do my IMS bearing?
All I need is for someone to do a 1:1 scan of it on a scanner, and then send me a file with the dimensions. A CAD drawing would be awesome, but not expected. I also need to know the thickness of the part.
I have the car torn apart, but the engine is not removed (986 3.2). My back is shot, so R&D'ing the part to make a new one from scratch is not looked forward to with enthusiasm, as it would require under-the-car gymnastics. No, well, not if someone could help me in this thread. lol
Before anybody says "You can't make those!", yes I can. I have a lathe and a mill in my basement, and a LOT of clean scrap steel plate.
I tried searching for such a subject, but failed.
BTW...That part is a $10 part if made in quantity.
FauxDiablo is offline   Reply With Quote
Old 07-13-2016, 02:16 PM   #2
I believe it's these...
Old 07-14-2016, 08:21 PM   #3
Pdwight's Avatar
Make me a set and I will pay you $20
Old 07-14-2016, 08:37 PM   #4
BirdDog's Avatar
Oops, never mind.
Old 07-14-2016, 10:26 PM   #5
Nine8Six's Avatar
My understanding is you don't need spec drawings at all. Make your own. Owning the M96 engine is all you need. Apparently;
Our porsche indy/specialist here regularly drop by my place to profile & machine parts off my manual mill so I can't imagine it as being that difficult using the basic engine measurements (which you already have). Hand written notes on a greasy piece of paper and off he goes.
All I know is his parts are all similar looking to those you posted. All for diff engines... he does it all himself mate, he's fun to watch also
Old 07-15-2016, 03:31 AM   #6
husker boxster's Avatar
If I understand his post correctly, he wants to build the parts before he tears the engine apart. Hence the request for dimensions.
1989 928 S4 5 spd - black
Old 07-15-2016, 03:44 AM   #7
Nine8Six's Avatar
Noticed the "back hurt" part just now also :/ I read faster than my little brain can follow. Too technical to explain, don't ask!
Just txt'ed my indy for pics, got "busy" as reply. Hopefully someone else can snap a high resolution pics with a ruler as reference. Think that'd be enough to get those 2D parts drawn quickly
Old 07-15-2016, 04:01 AM   #8
Beginner
Jamesp's Avatar
The year matters. The tool is different for 2003 and later.
2003 S manual
Old 07-15-2016, 08:08 AM   #9
1999 base
Meir's Avatar
these are the measurements for the 5 chains locking tool.
Old 07-15-2016, 11:34 AM   #10
flaps10's Avatar
^ 3 chain. The five chain is the long one with two locking tabs.
Old 07-15-2016, 02:01 PM   #11
1999 base
Meir's Avatar
the short tool is for the 5 chains as the the grooves in the camshafts do not line up.
you can lock only the lower camshaft. (which is fine as the 2 camshafts are connected via another chaine)
on the 3 chains they will line up, so you can tie them against each other with the long tool.
Old 07-15-2016, 08:39 PM   #12
OMG... I knew I should have checked this earlier!
I ended-up tweaking my back out to just make my own three-chain cam locks. Yes, they turned-out almost exactly like the one pictured above, but instead of a hole for bolt, I made an open-ended slot.
The one for the front, banks 1-3 is flat, The one for the back, banks 4-6 I made offset. Worked fine so far,
Thanks again!
PS...This is now a dead-end thread, as I am going to go post a new thread about what I found inside my IMS...
Old 07-16-2016, 12:56 AM   #13
800mm length, that's nearly a metre long, pretty bi tool, is it supposed to be 80mm?
rusty69911 is offline   Reply With Quote
Old 07-16-2016, 06:37 AM   #14
1999 base
Meir's Avatar
LOL!
Yes. It is 80.
Old 10-14-2023, 04:53 AM   #15
I know this is old thread but I need to make one of these. Is there any dimensions on the hole for locking it to the head ?+
johno2009 is offline   Reply With Quote
Old 10-14-2023, 05:24 AM   #16
elgyqc's Avatar
Ben Burner explains it all.
https://www.youtube.com/watch?v=UJ5WwbgQejs&list=PLiya6G1pHhIYyzhlVzS_LwoIovrlv6_lv&index=18&t=109s
Grant
