Originally Posted by flaps10
^ 3 chain. The five chain is the long one with two locking tabs.
the short tool is for the 5 chains as the the grooves in the camshafts do not line up.
you can lock only the lower camshaft. (which is fine as the 2 camshafts are connected via another chaine)
on the 3 chains they will line up, so you can tie them against each other with the long tool.
