Old 05-11-2015, 08:13 AM   #1
Perfectlap's Avatar
Lug nuts. Any good deals?
Have you had success with a reasonably priced set of aftermarket set of lug nuts?
My summer wheels went on this weekend and those lug nuts are looking not so hot and aren't going on so smooth.
BORN: March 2000 - FINLAND
Old 05-11-2015, 08:17 AM   #2
Chuck W.'s Avatar
Here are a few ...
qualityporscheparts | eBay
1995 Porsche C4 Cab
Old 05-11-2015, 08:40 AM   #3
Need For Speed
KRAM36's Avatar
Put caps on them. I have a set of these and they will not fall off. They look much better then the lug bolt too.
Porsche Black Lug Bolt Covers Caps All Models and Years Free Shipping Brand New | eBay
2003 Boxster S
Old 05-21-2015, 07:14 AM   #4
I was using those for a while and I agree that they look good on the car. My complaint with them is that they are very hard to pull off unless you grease them in which case they come off too easily and you find the occasional one missing (or rather, don't find it). After a few on-off cycles they tend to split, at which point they just fall off. anyway. they are a good solution to ugly lugs, but they do come with a downside.
I'd like to find a reasonably priced set in stainless or titanium. I'd settle for satin-finish chrome.
'99 black 986
Old 05-21-2015, 10:33 AM   #5
Perfectlap's Avatar
I had spline drive set of those on previous car. I sprayed a thin rubber coating in the socket that would fit.
didn't work out too well. Kind of a hassle to keep clean.
I'd like to see a Ti color Krylon spray I could just hit the OEM lugs with.
Old 05-21-2015, 12:18 PM   #6
BYprodriver's Avatar
Saw a set of titanium bolts on E-bay last week for $225 that's why I recommended Raynor look into making some.
Old 05-21-2015, 02:31 PM   #7
Pdwight's Avatar
Thanks for the Porsche Pucks
I ordered two, I had a set of generic pucks...but these are much better
Old 05-11-2015, 08:56 AM   #8
Perfectlap's Avatar
By the way, these are good to have in the frunk. They come in plastic. I have the metal one.
A hockey puck will work but these have the peg so you're in the right spot every time.
Lift Pad 97 04 Porsche Boxter 986 Jack Pad Adapter 1ea Blue Lift Puck Jackpad | eBay
Old 05-11-2015, 12:40 PM   #9
98 Arctic silver 986
tommy583's Avatar
I got this set. The quality seem great. 1998 Porsche Boxster Base H6 2.5L Wheels Bolts, Studs, & Nuts - PS19D28MWZNKT - Black Stock-Length Lug Bolts - Set Of 20 - ES#2598487
Old 05-21-2015, 04:56 AM   #10
I also got mine from ecstuning. They seem to have reasonable prices.
fredd5r is offline   Reply With Quote
Old 05-21-2015, 12:09 PM   #11
rdass623's Avatar
clean the old lugs with a wire wheel, apply a coat of spray paint to the caps and them apply a dab of grease to the threads of the bolts. quick easy fix for all of your problems. at 85ft/lbs of torque the will not come loose unless you take them off! there is no need to purchase a new set, they will only corrode like the old ones. by the way, the paint will come off after a while. all you need to do is simply repeat the process above. the can of spray paint will last longer than the car will. to me a $5.00 solution to replacing the lugs which will generally run about 10x more. just my $0.02
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
Old 05-21-2015, 03:29 PM   #12
Perfectlap's Avatar
It thought it was 96# lbs for the wheels...where's my manuel.
