Old 05-21-2015, 03:29 PM   #12
Perfectlap
Perfectlap's Avatar
Originally Posted by rdass623 View Post
clean the old lugs with a wire wheel, apply a coat of spray paint to the caps and them apply a dab of grease to the threads of the bolts. quick easy fix for all of your problems. at 85ft/lbs of torque the will not come loose unless you take them off! there is no need to purchase a new set, they will only corrode like the old ones. by the way, the paint will come off after a while. all you need to do is simply repeat the process above. the can of spray paint will last longer than the car will. to me a $5.00 solution to replacing the lugs which will generally run about 10x more. just my $0.02
It thought it was 96# lbs for the wheels...where's my manuel.
BORN: March 2000 - FINLAND
