Old 05-21-2015, 12:09 PM   #11
rdass623
rdass623's Avatar
clean the old lugs with a wire wheel, apply a coat of spray paint to the caps and them apply a dab of grease to the threads of the bolts. quick easy fix for all of your problems. at 85ft/lbs of torque the will not come loose unless you take them off! there is no need to purchase a new set, they will only corrode like the old ones. by the way, the paint will come off after a while. all you need to do is simply repeat the process above. the can of spray paint will last longer than the car will. to me a $5.00 solution to replacing the lugs which will generally run about 10x more. just my $0.02
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
