04-07-2015, 06:48 AM
#1
Best place to buy MAF?
I've been fighting a rough idle and dead spot between 3K-4K RPM's and narrowed to down to the MAF. Where's the most affordable place to get the MAF from?
Located in Central Mass.
'00 Boxster
04-07-2015, 08:05 AM
#4
I wonder how that company can do that price. It is lower than my cost by more than a bit. Great price, thanks for sharing that.
Erik
04-07-2015, 08:07 AM
#5
Almost 100% positive. If I unplug the MAF my idle smoothes out and the dead spot between 3K and 4K RPM's goes away.
'00 Boxster
04-07-2015, 08:16 AM
#6
Originally Posted by steved0x
I got mine from Amazon:
Amazon.com: Bosch 0280218055 Air Mass Sensor: Automotive
It looks like it has gone up a little since I got it, but still a good price.
I have a 2000 S so it should be the same part, but in case I got it wrong and am driving around with the wrong MAF please verify the part number for yourself
That is a great price.
1995 Porsche C4 Cab
04-07-2015, 08:33 AM
#7
^ probably an OEM QC reject sold at cut rate pricing to aftermarket re-sellers.
BORN: March 2000 - FINLAND
04-07-2015, 08:38 AM
#8
Check your chassis number. I can look it up to make sure you that you get the right part. There are two different parts for this depending on the chassis number.
Happy to help.
Erik Johnson
(970) 344-7761 phone
04-07-2015, 09:06 AM
#9
Erik do mean my VIN?
'00 Boxster
04-07-2015, 09:09 AM
#10
My Chassis # is YU625189 which means the newer MAF (BOSCH 0-280-218-055) correct?
'00 Boxster
04-07-2015, 09:34 AM
#11
Yikes I hope note  It has been working great for me, and Amazon has a good return policy so that can take a little risk out of it,
It had the hologram and everything on the box so I believe it to be genuine.
04-07-2015, 10:06 AM
#12
Well for $150 or literally 25% of what the dealer will charge why not. But I think someone mentioned once that Porsche have pretty strict testing of these before they are installed. There is apparently a wide variance on quality by Bosch. What doesn't make the cut goes on Amazon.
I guess the issue is do you want to replace it every two years for $150 or every 8 years for $600.
04-07-2015, 05:27 PM
#14
I bought mine, a Bosch, from RockAuto in February of 2013 for $170. Same one Amazon is selling for $145 now. Sunset Porsche is selling the OEM MAF for $401. Damn easy decision in my mind.
1995 Porsche C4 Cab
04-07-2015, 05:50 PM
#15
I bought one in January from Auto Haus AZ for $ 173.71
The Amazon deal looks good if your numbers match.
01 Boxster S (Sold)
79 SC Targa
73 914
15 Cayman S
04-08-2015, 06:30 AM
#16
I bought from Pelican due to their return policy and to support a vendor that supports the forum.
Their customer support is incredible.
I did return one MAF and the 2nd one also did not seem to fix the problem either but I found out that it was the electrical contacts in the MAF plug that was really the problem.
I sprayed MAF cleaner on the harness plug and MAF plug and all is well now.
Just make sure who ever you get it from has an excellent return policy.
"It broke because it wants to be Upgraded  "
04-08-2015, 06:36 AM
#17
Originally Posted by KRAM36
Do you buy all your parts from a Porsche dealer? If so I can see why you have spent $15k in repair cost.
That is a crazy good price for a new one, but even Pelican and ******************************************** sell the exact same part you would get from a Porsche dealer at about 1/3 the cost you posted.
I don't buy any of my parts from the dealer. Point is Porsche only use the top "1%" so to speak for this particular part. Those cut rate prices on Amazon in this instance reflect the units that do not meet the highest testing requirements by Porsche and did not pass. Allegedly, Bosch takes them back and price them accordingly. For whatever reasons Bosch have not mastered better quality control for this specific part, which probably means its something that is beyond their control perhaps some rare earth metal or something. Otherwise there would not be such a wide variance for this part unlike so many other parts that have a tighter margin.
Good deals are often worth taking a chance but they're a good deal for a reason.
High probability of under performance.
