Old 01-21-2015, 05:53 PM   #1
More's Avatar
Clutch Suggestions.
Hi
I'm thinking about putting a new clutch in when I put my new gearbox in to the Bosxter. Can someone recommend me a site with good prices?
Cheers.
1998 Porsche Boxster 986 Convertible.
More is offline   Reply With Quote
Old 01-21-2015, 06:27 PM   #2
flaps10's Avatar
Pelican?
When you hang up the phone, go check your porch. Pretty good chance the package is there.
I've spent about $1500 with them over the past few months. Their prices compare favorably with anyone.
I'm also a customer of LN Engineering, ECS, Vertex and Auto Atlanta.
Old 01-21-2015, 07:35 PM   #3
More,
It has been said many times but is worth repeating - check your DMF very carefully to the exact Factory procedure for wear.Rotational movement and axial are both important. If you get confused - ask here. A worn DMF is a great engine destruction device - particularly if it is poorly balanced. My new OEM DMF needed balancing! Yes,it is expensive to buy a new DMF and no the old ones have no core value.
The clutch fork was upgraded - did you check into that?
Old 01-21-2015, 09:36 PM   #4
Steve Tinker's Avatar
[QUOTE=flaps10;432722]Pelican?
I've spent about $1500 with them over the past few months. Their prices compare favorably with anyone. [QUOTE]
Its an awful long way from Pelican (Cal) to Sydney (Australia)....
More - Bob Whyms (?) Sydney should be able to give you a good price on a clutch kit - getting one from the US will be costly because of the shipping !
2001 MV Agusta F4.
Old 01-21-2015, 11:47 PM   #5
More's Avatar
[QUOTE=Steve Tinker;432748][QUOTE=flaps10;432722]Pelican?
Bob's a rip off merchant. He wants $2200 to put a gearbox in where a guy in Glebe 'Cavaco Motors' will do it for $1000. That's a huge difference.
Old 01-22-2015, 01:27 PM   #6
Manual trans swap is 8 hrs book time + $150 trans oil service (using the expensive factory fill). I know this because I asked my indy before I decided to DIY.
The calculation is left for the reader to perform (but I think that More has a point) ...
