Old 03-29-2014, 06:41 PM   #1
Jager's Avatar
Oh No The Jägermobile Broke Today!
The Jägermobile broke on the way to lunch today… Guess what happened?
Jäger
300K Mile Club
Old 03-29-2014, 06:47 PM   #2
Washer fluid leak?
Old 03-29-2014, 06:49 PM   #3
Jager's Avatar
Washer fluid leak?
Nope, it's full of washer fluid.
Jäger
300K Mile Club
Old 03-29-2014, 06:59 PM   #4
BIGJake111's Avatar
Fuel or Water pump?
Old 03-29-2014, 07:01 PM   #5
Jager's Avatar
Fuel or Water pump?
Nope... But good guess.
Jäger
300K Mile Club
Old 03-29-2014, 07:02 PM   #6
BIGJake111's Avatar
Headlight fluid then :troll:
Old 03-29-2014, 07:06 PM   #7
Broken half shaft?
Old 03-29-2014, 07:14 PM   #8
Rock hit your oil filter housing
Polaris is offline   Reply With Quote
Old 03-29-2014, 07:16 PM   #9
Jager's Avatar
Negative... What kind of roads do you drive on??
Jäger
300K Mile Club
Old 03-29-2014, 07:18 PM   #10
BIGJake111's Avatar
Aos but wouldnt this be your like 18th aos haha.
Old 03-29-2014, 07:21 PM   #11
Jager's Avatar
You are correct... AOS... It will be my third AOS. I already removed it and ordered another one. I will probably install next weekend. Why can't Porsche improve this part??
Jäger
300K Mile Club
Old 03-29-2014, 07:40 PM   #12
BIGJake111's Avatar
Wouldve been my first guess if it wasnt for you having replaces so many times before, i am assuming mine is on its original, and has 106k miles... time to look into some preventive m.
hope you have your box running in no time!
Old 03-30-2014, 11:21 AM   #13
Perfectlap's Avatar
Because they have to admit the Yanks have a better, non-engine-endangering system. Porsche's is not even a good execution...
BORN: March 2000 - FINLAND
Old 03-29-2014, 07:23 PM   #14
Is the flatbed voluntary or mandatory?
nicecar is offline   Reply With Quote
Old 03-30-2014, 09:26 AM   #15
rp17's Avatar
Mandatory! AOS is the only maintenance item I have left on my list. Maybe this year.
Jager what were your symptons? Big cloud of smoke?
Old 03-30-2014, 01:01 PM   #16
DennisAN's Avatar
I'm still trying to figure out the function of the AOS. Isn't it roughly equivalent in function to an old-fashioned PCV valve?
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
DennisAN is offline   Reply With Quote
Old 03-31-2014, 09:57 AM   #17
Registered Boxster abuser
healthservices's Avatar
Yes like a pcv but because the motor is a flat 6 it has a harder time controlling the oil vapors. Its also different from a pcv in that the porsche uses a close crankcase system with no vent. So in instances where a motor has more blowby and higher load it tends to force the blowby back into the intake.
Sent from my SM-T310 using Tapatalk
Old 03-31-2014, 10:37 AM   #18
DennisAN's Avatar
In that case...what does Subaru do? They're the only other flat boxer motors being built today IIUC.
Other cars I've worked on have two vents. One is the PCV valve connecting the crankcase to the intake manifold on the engine side of the throttle plate. The other is a plain tube vent (perhaps with a flow restrictor) connecting the crankcase to the intake plumbing between the MAF sensor and the throttle plate. Is the AOS a combination of these two functions?
Old 03-31-2014, 09:59 AM   #19
Just out of curiosity do you do a lot of engine braking? I wonder if that has an effect on the aos?
Old 03-31-2014, 06:11 PM   #20
Jager's Avatar
No, I very rarely down-shift and use the engine to brake.
Jäger
300K Mile Club
