03-29-2014, 06:41 PM
Oh No The Jägermobile Broke Today!
The Jägermobile broke on the way to lunch today… Guess what happened?
Jäger
300K Mile Club
03-29-2014, 06:47 PM
Washer fluid leak?
03-29-2014, 06:49 PM
Originally Posted by dghii
Washer fluid leak?
Nope, it's full of washer fluid.
Jäger
300K Mile Club
03-29-2014, 06:59 PM
Fuel or Water pump?
03-29-2014, 07:01 PM
Originally Posted by BIGJake111
Fuel or Water pump?
Nope... But good guess.
Jäger
300K Mile Club
03-29-2014, 07:02 PM
Headlight fluid then :troll:
03-29-2014, 07:06 PM
Broken half shaft?
03-29-2014, 07:08 PM
Nope... Not a good guess.
Hint: There was a pool of oil under the motor on the Drivers side when off-loaded from the tow truck.
Jäger
300K Mile Club
03-29-2014, 07:14 PM
Rock hit your oil filter housing
03-29-2014, 07:16 PM
Negative... What kind of roads do you drive on??
Jäger
300K Mile Club
03-29-2014, 07:18 PM
Aos but wouldnt this be your like 18th aos haha.
03-29-2014, 07:21 PM
You are correct... AOS... It will be my third AOS. I already removed it and ordered another one. I will probably install next weekend. Why can't Porsche improve this part??
Jäger
300K Mile Club
03-29-2014, 07:23 PM
Is the flatbed voluntary or mandatory?
03-29-2014, 07:40 PM
Wouldve been my first guess if it wasnt for you having replaces so many times before, i am assuming mine is on its original, and has 106k miles... time to look into some preventive m.
hope you have your box running in no time!
03-29-2014, 07:45 PM
Now that I think of it... I replaced the AOS three times so this makes it number four for this Boxster.
Jäger
300K Mile Club
03-29-2014, 07:46 PM
Beginner
What path did the oil take to end up under the left side of the engine?
2003 S manual
03-29-2014, 07:49 PM
Through the induction system over to the Air Box below the air filter... There is a drain at the bottom of the Air Box.
Jäger
300K Mile Club
03-30-2014, 05:54 AM
Ok Monday morning QB time
Are there indications you can think back on that may have been due to the AOS failing?
So when the AOS fails, does the car become un-driveable or in this case it was the oil leakage that scared you?
I was going to guess you lost one of your tire's valve stem caps
Seal Grey
03-30-2014, 06:49 AM
What in the world would cause your AOS to fail 4 times? Seems like maybe it's a symptom of a root cause problem that hasn't been addressed.
Dave S.
2003 Boxster S
03-30-2014, 06:57 AM
Engine Surgeon
Operating environment being near sea level doesn't help as atmospheric pressures are greatest there and pout more load on the AOS internals.
I find that extended oil service intervals lead to this more than anything as acids in the oil reach levels that create diaphragm degradation within the AOS.
US Patent 8,992,089 &
US Patent 9,416,697
