Old 01-25-2016, 06:12 PM   #41
Pdwight's Avatar
Originally Posted by Cloudsurfer View Post
Given your mileage, I wouldn't even dream of only replacing one side header/ cat.
Replace both cats and at least both pre-cat O2 sensors.
As to the bolts, while I have yet to have one shear off in a head, def take your time and use a quality penetrating oil like PB Blaster.
Can I have your other Porsche sticker for my tool box
Old 01-25-2016, 06:54 PM   #42
Jager's Avatar
It’s actually a magnet... Yes you can have one.
Jäger
300K Mile Club
Old 02-03-2016, 06:30 AM   #43
Need help with the same problem
Hi guys,
I'm having the same exact symptoms as Jager with my 02 Bosxter base with 96,000Kmiles.
I have been getting a CEL every now and then for the past year, which I reset using my Durametric.
Problem is I'm due for smog inspection (California) and my renewal indicates that I must take the car to a STAR station. (those who live in CA know what that means.)
So, I reset the last CEL and took the car in. 15 minutes later the tech came to the waiting area and informed me that the OBD indicated that the car wasn't in "Ready" state to be tested. He asked if I had any repairs done, or had the battery disconnected? I said no! I was told to drive the car for approximately 80 miles and take it back for another try.
After 90 miles of driving, I checked the Ready Status and only "Catalytic Convertor Efficiency" was still in Fail state.
After some research on the web, I came across a statement which said, in CA, on 2000 and later cars, with one out of 5 readiness monitors off, the station can proceed with testing the vehicle.
So I go beck to the smog station and they refused to test the car because of the one readiness monitor being in fail mode.
Since, I have driven the car for another 120 miles and the cat readiness monitor doesn't want to go into pass mode. BTW, no CEL either.
Based on the above, I have two key questions:
1) Will a failing cat prevent the respective readiness monitor from resetting?
2) Is it true that I should be able to get the car smogged with 1 of 5 monitors in fail sate?
As always, I would greatly appreciate any and all input.
TIA
seventythree is offline   Reply With Quote
Old 02-03-2016, 11:58 AM   #44
jb92563's Avatar
The Cats are designed to last forever basically and this would be true it they never became fouled by oil in the exhaust over a long period of time, excessive temperature (overly rich unburnt fuel getting into exhaust) or mechanical failure of the converter element (rock smashed Cat or Internal cement came apart causing cat element to loose its seal and allowing exhaust to bypass the element).
I had a Cat failure at 75K miles due to the cat element cement losing its seal.
You can hear the element sliding back in forth inside if you shake the removed cat.
I replaced it with a used one from ebay since Dismantler Businesses are not allowed to sell them used in CA. Works better than the other banks cat now and cost ~$250 vs the ~$1800 for a new one.
I used a scope through the front O2 sensor after my AOS failure a few years ago, figuring that I had oil fouled the cats but it looks fine.
Old 02-03-2016, 12:06 PM   #45
jb92563's Avatar
They keep changing the rules yearly. In 2015 they don't use the tailpipe sniffer on 2000 and newer cars and only rely on the computers diagnostic report so the CAT condition diagnostic would be mandatory so if THAT subsystem was not showing ready they can not pass your car.
Old 02-06-2016, 09:00 AM   #46
Thanks jb for your response.
Guys, I'm getting a little desperate here. I've been monitoring the O2 sensor voltages before and after the precat for both banks 1 & 2.
First off, while ideling, both banks look fine. Before cat is sinusoidal and after cat is fairly flat at around 0.8v.
While driving, the after cat voltages are fairly jumpy with bank 2 being a little worse. However, the before voltages aren't consistently up & down and seem to skip a beat quite often.
I am getting desperate because I don't want to spend 6 hours on my back changing out the precats just to find out the problem is still there. (I am a pretty accomplished DIY mechanic but having to wear reading glasses most of the time has taken a lot of the fun out of it.)
To recap the problem, the cat efficiency monitor is stuck in Fail state and won't switch to Pass even after ~300 miles of driving. The other 4 monitors are in Pass state and I haven't got another CEL since I turned off the last one and tried to smog the car 9 days ago. It's a 2002 Boxster base with 96 Kmiles.
Please respond if you can help me diagnose the problem with more accuracy.
Thanks again.
PS, If I let the car idle for a minute or two, the period on the sine wave becomes as tight (short) as we see in most illustrations. However, the period is much longer most other times.
Old 02-06-2016, 09:35 AM   #47
Thanks again.
If you are throwing P0420 and/or P0430, and you know there is nothing wrong with the O2 sensors, you have bad cats, which are not going the heal on their own. You are also not going to sneak this past the emissions inspection.
Old 02-06-2016, 12:57 PM   #48
Thanks JFP,
Can you guide me through the process of eliminating the O2 sensors as a culprit.
I just want to tackle the pre-cat replacement project with more confidence.
TIA
Old 02-06-2016, 01:27 PM   #49
How about we start with what codes is the car throwing, and what voltages are seeing for the O2 sensors ahead of the cats and behind them?
Old 02-06-2016, 03:58 PM   #50
For about 6 months I had been getting P0430. Only once I got a P0420.
But for the past 10 days and 350 miles, since cat efficiency monitor has been in fail state, no codes whatsoever.
When I start the car, all four voltages fluctuate between .05 and .8 volts.
Once warmed up, while driving on the freeway at around 70mph, both voltages ahead of cat fluctuate between .1 and .75 volts; voltages after fluctuate from .5 to .75 volts with bank 2 fluctuating more, and more often than bank 1.
While decelerating under engine braking all four drop to near zero.
After a long drive, if I let the engine idle for 2-3 minutes, voltages ahead fluctuate between .05 & .8 volts; voltages after from .6 to .75 with bank 2 fluctuating more.
I hope this is sheds more light on the problem.
Old 02-07-2016, 06:01 AM   #51
Your sensors are fine, you have a cat issue.
Old 03-13-2016, 03:21 PM   #52
Swhitcomb's Avatar
Got an 0430 on my 2002 Boxster yesterday. Cleared it and it hasn't returned.
Pulled this from Torque
http://youtu.be/oKFTjd00a6Y
Cat bad or O2 sensor?
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Swhitcomb is offline   Reply With Quote
Old 04-29-2017, 09:42 AM   #53
People with a suspect cat are reluctant to spend the money on an expensive replacement if they are unsure of both the diagnosis and result.But with a looming Smog Test there is only one cheap diagnostic test I can think of .It is not a permanent fix and it is illegal to drive with the test parts in place. It is just to use long enough to monitor the voltage of all 4 O2 sensors.
Use SHORT anti-foulers or extenders on the rear O 2 sensor of the failing(?) cat . On Bank 2 there is space.Bank 1 requires more creativity.
You can also try cleaning the cat. Neither of these are smart fixes imho but they may ' get you by' - but just to test. Be aware the extender may cause a lean code !
The extender will cause the rear O2 sensor voltage to 'flat-line' and look like the cat is working. This is your clue to replace the cat - assuming all the other suspects have been eliminated/replaced with correct ,new parts - coils,O2 sensors,plugs,vac leaks all other related codes.
Old 04-29-2017, 08:56 PM   #54
I am my own mechanic....
Timco's Avatar
Um, you just answered a thread from over a year ago....
Better late than never.
'08 VW Touareg T-3 wife's car
Old 12-09-2019, 12:44 PM   #55
Waking up a sleeping thread
I know it's been a few years since anybody posted to this thread, but I have a question.
According to what I've read here, and what my Durametric tells me, both of my cats are excrement. The sensor voltage behind both cats is all over the place. Before I go spending a bunch of money, can I tell from Durametric of the sensors giving me those readings are good? Resistance on the sensors on both sides shows basically zero (steady) behind the cats, and both show a steady value forward of the cats too (sorry I didn't note the actual values forward, but with both bank's showing, the line for the value forward of the cats showed both at an identical value and unwavering.
Is that how good sensors should read?
And BTW, which cats are we actually talking about? The ones that are part of the exhaust manifolds, or the ones downstream, just prior to the muffler?
Also, since cats cost as much as they do, I'm thinking I'll just replace the system with a Fabspeed exhaust from Pelican Parts. Specifically, Pelican Parts part number FAB-986-MAXKT-M. It looks to me like it replaces everything aft of the exhaust manifolds. If I replace the entire system, including replacing the OEM manifolds with headers (eliminating those cats), what problems am I likely to run into? I don't care about emissions, since we don't have emissions testing where I live. More interested in what effect that would have due to (i'm guessing) eliminating the O2 sensors in question.
Anybody here have experience with the Fabspeed exhaust?
Tweetdriver63 is offline   Reply With Quote
Old 12-09-2019, 01:00 PM   #56
BYprodriver's Avatar
According to what I've read here, and what my Durametric tells me, both of my cats are ****************. The sensor voltage behind both cats is all over the place. Before I go spending a bunch of money, can I tell from Durametric of the sensors giving me those readings are good? Resistance on the sensors on both sides shows basically zero (steady) behind the cats, and both show a steady value forward of the cats too (sorry I didn't note the actual values forward, but with both bank's showing, the line for the value forward of the cats showed both at an identical value and unwavering.
I just bolted my Fabspeeds on but doubt they will pass smog.
I will sell my oe manifolds for $ 300 guaranteed to pass any smog test, they have had a easy life since I rebuilt my engine in 2010. Thanks for searching.
Old 12-09-2019, 03:13 PM   #57
FWIW I have the Fabspeed Sport headers with catalysts, Circuit Werks mid pipes without catalysts, just small silencers in their place, and the stock U pipes and muffler on my 2003 S which was rebuilt as a 3.6 and has a custom Softronic tune. I have the stock O2 sensors, not those special sensors designed to trick the ECU. My car passed the NJ State inspection at a State DMV inspection center, where the only things done are to see that your check engine light is off and hook up their OBD system to your car and make sure it isn't throwing any codes.
