Old 04-14-2013, 07:55 PM   #1
evo-r's Avatar
Question Alternate tire size options for 17" Sport Classic wheels?
I'm looking to replace all 4 tires and think the stock front tire size is too narrow. I'm thinking about running 225-50 up front and the current 255 width in the rear is fine with me but what other tire spec have you guys ran on the stock Boxster 17" wheels?
Note: I'm aware that if I do go with 225 front then the speedo will be off by 3% but will gain some comfort.
Sport Classic Wheel Spec:
Front: 17x7 ET55
Rear: 17x8.5 ET50
It's been 2 weeks since ownership and I finally got to wash and wax her...
His: 2003 Boxster & 2008 MDX
Hers: 2011 Golf TDI
evo-r is offline   Reply With Quote
Old 04-14-2013, 08:17 PM   #2
Track rat
Topless's Avatar
225/45/17 will retain your 25" total diameter and give you more grip up front. A good choice.
Old 04-14-2013, 08:22 PM   #3
Good looking white Box.White is rare.I have only seen 2 and they are eye catching for sure.
litespeedp is offline   Reply With Quote
Old 04-15-2013, 06:06 AM   #4
Medicated Open-Air Driver
Needs some help.....I have a 2005 Boxster with the following tire sizes:
Front: 205/55/ZR17
Back: 235/50/ZR17
Are you saying the 225/45/17 can go on the front? What are the advantages? How about the back? Should/can I put 255/?/17 on the back? Recommendations? Regards!
BDBoxster is offline   Reply With Quote
Old 04-15-2013, 06:24 AM   #5
Yes, go 225/45/17 Front and 255/40/17 on rear. Those sizes have matching diameters so no impact to speedometer or ABS performance. These are the tire sizes that almost every Boxster runs.
The advantage to the 225 fronts is a bit more front end grip and thus, slightly less understeer for more balanced handling.
Old 04-15-2013, 06:41 AM   #6
Excellent! Many thanks!!!!
Old 04-15-2013, 06:45 AM   #7
I ran 265/40/17 in back for a while. It looked and rode fine. I later noticed that the minimum width for 265's was nine inches. I'm kind of a stickler for following wheel/tire width specs so I replaced with 255's the next time around.
Wret is offline   Reply With Quote
Old 04-15-2013, 10:16 AM   #8
evo-r's Avatar
Just ordered the following set from TireRack, thanks guys!
Conti DWS
225-45-17
255-40-17
Hers: 2011 Golf TDI
