Old 01-18-2013, 03:19 PM   #1
oc-boxster's Avatar
repair quote
hey guys,
finally got my car in to my local indy mechanic for inspection, as i was getting some clutch chatter and slip. he reported back that it needs a new clutch kit, flywheel, and im going to do LN ims upgrade while its apart my factory bearing is leaking at the seal, the quote is for 3700 parts and labor. is this online with what you guys paid when you went through this common procedure? the mechanic is going to send some photos of all the old parts ill post when i get them he said 2 of the fingers on the pressure plate were cracked and the throw out bearing was pretty bad..
oc-boxster is offline   Reply With Quote
