Old 08-14-2012, 01:53 PM   #41
Mobile Porsche Surgeon
kashmir's Avatar
Have a good lunch.
Mike's Specialty Porsche Service
Mobile Mechanic Specializing in Porsche and Select Automobiles
http://www.mikesspecialtyautomotiveservice.com/index.html
Early 1996 / 97 Boxster, 130 k, De snorkeled, IMS, Top Speed Headers.
kashmir is offline   Reply With Quote
Old 08-14-2012, 01:55 PM   #42
kashmir's Avatar
Move seats forword.
Old 08-14-2012, 01:56 PM   #43
Theoretical propagandist
Eric G's Avatar
Looking really good. Did your flywheel pass the twist test or is it shot? I know its pricey but a good time to replace it now.
Going to be anxious to see how your bearing looks when you get it out. Take your time and triple check you have everything locked down, and for what its worth, loosen all three of your cam chain tensioners. It really does make a big deal.
Waiting to see your next installment!
Old 08-14-2012, 01:58 PM   #44
kashmir's Avatar
Remove front engine access.
Old 08-14-2012, 02:01 PM   #45
kashmir's Avatar
Its shot checking prices now.
Old 08-14-2012, 02:10 PM   #46
kashmir's Avatar
Cleaned up for the day and have gone car shopping. :dance:
Old 08-15-2012, 12:17 PM   #47
kashmir's Avatar
Access to front of engine.
Old 08-15-2012, 12:25 PM   #48
kashmir's Avatar
Rotate motor clockwise until tdc lines up on the main pulley.
Old 08-15-2012, 12:34 PM   #49
kashmir's Avatar
Split apart pulley lock so that it will clear the power top motor shroud and insert into teardrop shaped hole on pulley.
Reattach red handle.
Old 08-15-2012, 12:51 PM   #50
kashmir's Avatar
On bank one (the passenger side on USA cars) pulls the green plug on flywheel end of engine.
Old 08-15-2012, 01:06 PM   #51
kashmir's Avatar
If notch is pointing away from motor, according to my manual you are NOT at TDC.
Must undo pulley lock and rotate engine clockwise 360 deg.
Put tool back into the teardrop hole.
Old 08-15-2012, 01:10 PM   #52
kashmir's Avatar
Now the notch on the cam is pointing inward.
Old 08-15-2012, 01:22 PM   #53
kashmir's Avatar
Notch is pointing inward on bank one, you are at top dead center,
Old 08-15-2012, 01:28 PM   #54
kashmir's Avatar
On the 5 chain engine you only have to pull the bottom green plugs
Old 08-15-2012, 01:36 PM   #55
kashmir's Avatar
On 5 chain motor use the sort cam lock, mine I had to notch with dremel to clear engine flange.
Lock onto cam.
I am going to order one more cam lock for bank one.
Old 08-15-2012, 01:41 PM   #56
kashmir's Avatar
Cut 12" flat stock, drill two holes, lock down flywheel.
Old 08-15-2012, 03:42 PM   #57
Is it necessary to lock the crank at the rear of the engine if you've already pinned the crank at the front? Just wondering.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 08-15-2012, 04:33 PM   #58
Eric G's Avatar
It is cheap insurance that nothing moves. I did it on mine and nothing moved.
Old 09-13-2012, 12:15 PM   #59
kashmir's Avatar
Take 32 mm socket and remove the two front chain tensioner.
This part is were some confusion comes in. I have developt a hybrid of Pelicans Parts and LN engineering instructions.
Old 09-13-2012, 12:18 PM   #60
kashmir's Avatar
Remove nut on bearing shaft.
