Old 05-15-2012, 06:10 PM   #1
Do you lowered guys have problems?
I just lowered my car 1 inch with lowering springs.
It rubs when I turn the steering wheel all the way. Is that normal? What was your solution? Can the plastic trim around the front wheels be removed?
Will I have rubbing problems when turning fast at high speeds at a Race track?
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
Old 05-15-2012, 06:12 PM   #2
Johnny Danger's Avatar
The inner shields are adjustable . Take a closer look and you will see .
Old 05-16-2012, 04:47 AM   #3
When you say inner shields, are you talking about the plastic trim around the wheel? Inner fender.
00 2.7 5SPD MT
Old 05-16-2012, 05:09 AM   #4
And does this look too low for a 1 inch drop?
The incline on the driveway is not at a high angle, but my bumper + lip still scrapes.
00 2.7 5SPD MT
Old 05-16-2012, 06:09 AM   #5
MN 986's Avatar
I am not lowered (yet, ROW M030 coming soon, if hat counts as lowered), but with my AerokitII bumper with larger GT3 splitter is almost as low as yours and I have the same driveway angle. Maybe you do this already, but I can avoid scraping by entering/exiting the driveway at an angle. If one wheel hits the ramp before the other, you end up with a little extra room versus both wheels at once.
I hope that helps!
MN 986 is offline   Reply With Quote
Old 05-16-2012, 06:14 AM   #6
Assuming that we're talking about the same thing, if your front tires are making contact with the plastic shield that's located inside the wheel well itself, it can be adjusted . I had a similar problem after my vehicle underwent a body kit project, wherein my front wheels were making contact with the shield . It's been awhile since the project, but I recall that the shields were adjustable, and I was able to move them inward to eliminate this problem .
Old 05-16-2012, 06:27 AM   #7
No problems here. Lowered 1" with H& R springs with aero kit and no rubbing lock to lock.
02 Boxster (DD sans kids)
08 Corvette Z06 (Track car)
Old 05-16-2012, 07:07 AM   #8
I hope that helps!
Yeah I tried that too. It was the same result but not as bad. As you can see in this picture, my front wheels are still on the driveway. They have not even reached the lower black pavement yet.
00 2.7 5SPD MT
Old 05-16-2012, 07:09 AM   #9
So you track your Boxster with the 1 inch lowered suspension? Did you ever experience rubbing from making fast turns on the track?
00 2.7 5SPD MT
Old 05-16-2012, 08:02 AM   #10
Bear in mind that the rubbing typically only occurs when your wheels are near lock, meaning an extremely tight turn. On track, at speed, rarely do you get anywhere near tight enough of a turn to cause the rubbing, unless it happens frequently on the street, with only the slightest turn of the wheel.
Usually the rubbing only occurs at parking-lot speeds.
NoGaBiker is offline   Reply With Quote
Old 05-16-2012, 08:16 AM   #11
Yeah it only happens at lock.
But I still don't know how much body roll there will be at track speeds and how close it will get to the tire.
It is okay in normal driving.
00 2.7 5SPD MT
Old 05-16-2012, 08:39 AM   #12
Topless's Avatar
Mine is lowered and rubs a bit at full lock with 255s on the front. No rub with 225s. Did you have your wheel alignment done after lowering? What were the values?
Old 05-16-2012, 09:43 AM   #13
Yeah they couldn't get it perfect. I don't have the values on me, but I will try and post them later.
00 2.7 5SPD MT
Old 05-16-2012, 10:28 AM   #14
jcb986's Avatar
Ok, why would anyone what to lower a Porsche. :ah:
Old Hippie Young Heart
Old 05-16-2012, 10:48 AM   #15
If your tires are rubbing the inner fender at the track, I am sure that you will have bigger concerns than the rubbing itself...
PS, the rubbing may be eliminated with a wheel spacer
Old 05-16-2012, 01:10 PM   #16
ChrisZang's Avatar
lowered by about 1 1/2" with 7mm wheel spacers all around
lots of rubbing at the front wheels (fender liners and the blue steel line inside the driver's side fender)
Old 05-16-2012, 05:15 PM   #17
The red part, or rather a bit more inner, is where the tire hits the plastic inner fender when turned all the way. So it hits from the front, not the top.
Also, now the metal shield behind the rotor is touching the brake rotor in the right rear wheel where the camber is most negative.
How can I solve that problem? I tried to bend it away, but there is a strong metal suspension component behind the metal shield that does not let me bend it away.
And Alignment results after lowering it were:
Toe:
Front Right: 0.05 degrees
Front Left: 0.03 degrees
Rear Right: 0.11 degrees
Rear Left: 0.09 degrees
Camber
-0.1 degrees for both fronts.
Rear Right: -1.6 degrees
Rear Left: -1.4 degrees
Caster
7.8 degrees
00 2.7 5SPD MT
Old 05-16-2012, 06:31 PM   #18
Toe:
Camber
Caster
7.8 degrees
For the second time, the inner shields are adjustable. Remove your wheel(s), and look behind the shields . You'll discover that the tabs (or whatever they're called) can be adjusted to allow them to be moved inward toward the bumper . This should create enough space for the tires to clear .
Old 05-17-2012, 04:19 AM   #19
I didn't notice the tabs when I looked. I was trying to adjust it like you said before I posted this picture. I guess I will take the wheels off and check it out again later.
In other news, because of my clogged A/C lines and the hard rain in Philly the other day, I literally had about 4 gallons of water under my passenger seat. I vacuumed most of it out. I also found a couple of tobacco products under my carpet under the passenger seat and the water had a white powerdery substance floating in it?!?!
00 2.7 5SPD MT
Old 05-17-2012, 05:16 AM   #20
SoK
How did the water get into the car?
2001 Seal Gray 5-Speed - 2007 Yamaha R6 - 2003 Honda Civic EX - 1999 Nissan Frontier XE - 2003 Coleman Utah
SoK is offline   Reply With Quote
