Old 12-20-2011, 05:54 AM   #1
2003S's Avatar
Brake Fluid
As I pulled into work this morning, the dash alternated between "Brake Fluid Low" and "PSM Disabled" -- Am I right in assuming the former probably causes the latter? Didn't have chance to open the frunk & check the level, was running late for a call.
Assuming I just need to add fluid, which is the right one? Pelican sells:
  • ATE Super
  • ATE Gold
  • ATE DOT 4
  • ATE SL.6 DOT 4
  • Pentosin DOT 4
2003 Midnight Blue S
LN IMS Retrofit
Old 12-20-2011, 07:53 AM   #2
Topless's Avatar
Any DOT4 will work. The more important question is, how did the fluid get so low? What do the pads and rotors look like? Really low fluid usually means either a leak or total brake job. Give it a good look before driving.
Old 12-20-2011, 07:59 AM   #3
2003S's Avatar
Pads & Rotors looked great @ the PPI in Sept, probably just 1K miles ago, so I'm doubting anything major happened there -- but I will take a close look before I leave the office today. Hoping it's just a bit low, the warning didn't come on until I was pulling into my parking spot, all was fine the whole way in...
LN IMS Retrofit
Old 12-20-2011, 10:44 AM   #4
  • ATE Super
  • ATE Gold
  • ATE DOT 4
  • ATE SL.6 DOT 4
  • Pentosin DOT 4
You do not want to use the ATE Sl.6, which is a special low viscosity fluid for use in some cars that require it for their stability management systems; any of the rest of them would be fine.
Old 12-20-2011, 10:44 AM   #5
2003S's Avatar
So it just looks a bit low; Nothing under the car, so not sure what the deal is.
I'm parked on a bit of a slope in the parking garage, but you can still tell it looks to be below the "min" line by a bit.
Any problem with topping it off? e.g. potentially mixing different types of fluid?
LN IMS Retrofit
Old 12-20-2011, 10:49 AM   #6
The system shuts off the PSM when the fluid level gets too low to prevent pulling air into the network of pump and control valves, which is a pain to bleed out and requires activating the system while bleeding using either a PIWIS or Durametric system.
Old 12-20-2011, 01:04 PM   #7
2003S's Avatar
Thanks much.
LN IMS Retrofit
Old 12-20-2011, 06:18 PM   #8
Don't forget the brakes and clutch are on a shared system.
