Thread: Brake Fluid
Old 12-20-2011, 10:44 AM   #4
JFP in PA
Originally Posted by 2003S View Post
As I pulled into work this morning, the dash alternated between "Brake Fluid Low" and "PSM Disabled" -- Am I right in assuming the former probably causes the latter? Didn't have chance to open the frunk & check the level, was running late for a call.
Assuming I just need to add fluid, which is the right one? Pelican sells:
  • ATE Super
  • ATE Gold
  • ATE DOT 4
  • ATE SL.6 DOT 4
  • Pentosin DOT 4
You do not want to use the ATE Sl.6, which is a special low viscosity fluid for use in some cars that require it for their stability management systems; any of the rest of them would be fine.
