As I pulled into work this morning, the dash alternated between "Brake Fluid Low" and "PSM Disabled" -- Am I right in assuming the former probably causes the latter? Didn't have chance to open the frunk & check the level, was running late for a call.
Assuming I just need to add fluid, which is the right one? Pelican sells:
- ATE Super
- ATE Gold
- ATE DOT 4
- ATE SL.6 DOT 4
- Pentosin DOT 4
