Old 10-05-2011, 09:49 AM   #21
Yeah, the gear ratio in the transmission is astronomical. Running the cable with a cordless drill is sloooowwwww - makes you realize that the top motor is really whizzing right along. Save yourself a lot of hassle and just remove the boomerangs and covers on both sides, put the boomerangs back, and then line them up to the timing marks with the drill.
2002 Boxster S, Arctic Silver, 18" Turbo Wheels, 6-speed
peterbrown77 is offline   Reply With Quote
Old 10-05-2011, 09:51 AM   #22
Originally Posted by insite View Post
there are actually alignment marks on the transmissions
I have seen one mark on the transmission.
keithl is offline   Reply With Quote
Old 10-05-2011, 12:07 PM   #23
Mine had 4 hash marks on the aluminum case, corresponding to the outline of the boomerang.
Old 10-05-2011, 07:06 PM   #24
Looks like i have one mark on the one i removed. I probably wont get to putting it back together until the weekend. Thanks a lot, i appreciate the help!
Old 10-06-2011, 09:14 AM   #25
at least it will give you a reference. Having both levers in the same position is critical, not which position they happen to be. The links are long and even small misalignments make the top/cover come down crooked.
Old 10-06-2011, 08:28 PM   #26
The level works. Don't make this difficult!
Honestly...use the level to get the two arms in the same position (or very close) and then connect the clamshell, lower the thing and check your alignment. You'll see once you start this that it is not magic. Just play with it a bit and you'll see.
I've done two boxsters this way and have not spent more than 15 minutes getting things lined up after starting with the level.
Old 10-09-2011, 05:13 PM   #27
Well, i had it fixed. The top went up and down twice and seemed to close perfectly,
Then the otherside got stuck closed. I had to disconnect the other side to get the top
To close. I may have something else going on, i dont know. Next weekend Im going to take both sides apart and start over...
Old 10-10-2011, 06:37 AM   #28
describe exactly how it happens when it gets stuck.
i had a similar issue to this. what would happen is this:
1) open the top (all is well)
2) try to close the top, but it would seem like the motor was trying to close it more instead of open it
3) stuck.
the culprit? there is a microswitch behind the driver's door that tells the convertible top motor to switch directions after the clamshell cycles. if it goes bad, the motor won't switch directions & the clamshell will get stuck.
insite
'99 Boxster
3.4L Conversion
Old 10-10-2011, 10:01 AM   #29
Yeah, but he is saying it is one side stuck, not a failure to move at all.... Since it is a common motor driving the cables, it shouldn't be the microswitch.
Old 10-10-2011, 11:25 AM   #30
I am wondering if the other side cable broke now because it had to work extra hard the last few times I tried to opened it when the passenger side cable was broken. I guess I'll buy another cable anyway and install a new one on that side too sync them up and try again. If that doesn't work, I'll look into everything else. Weird. Thanks for the suggestions everyone!
Old 10-11-2011, 09:13 AM   #31
Insite may have a point though - if the microswitch is failing then perhaps it tried to drive the top in the wrong direction and broke your cable...
Old 10-13-2011, 03:07 PM   #32
Well the cable was broken on the otherside. And it turns out the original side i was having trouble with was off the track. I took both sides off, lined up the marks on the transmissions, installed the new cable, adjusted the microswitch so it matched the other side and now it works perfectly. Kind of an adventure, but Im glad it's working.
Thanks a lot! I couldn't have done it without help from you guys.
Old 06-27-2016, 02:06 PM   #33
Originally Posted by keithl View Post
Removed the clip, got it open. The passenger side transmission doesnt turn, when the top is operated. Does that mean the cable on that side is broken? How does the plastic cover on the motor for the top come off? Thanks.
Is this the clip you are talking about? I'm having the same problem just new to the Porsche world and not a gearhead
Addymac615 is offline   Reply With Quote
Old 06-27-2016, 06:46 PM   #34
Yes,that would be the clip
Old 07-31-2016, 12:31 PM   #35
Reconnecting Conv. Top Strut
I was able to disconnect the top strut to release the tension to get my top down finally. Can anyone tell me now how to reconnect it? It seems impossible to stretch out to reconnect. Thanks for your help.
flewis99 is offline   Reply With Quote
Old 08-01-2016, 06:48 AM   #36
It doesn't stretch out. The other parts move to line things up.
"YouTube Certified in Various Specialties"
Old 08-05-2016, 01:33 PM   #37
Thanks Bfeller,
Does that mean that I need to disconnect parts such as the boomerang, fit it to the strut and then find a way to then fit the boomerang? Is there some where I can find out diagram, or step by step process?
Old 08-05-2016, 01:54 PM   #38
911monty's Avatar
You should find the attached useful to set up the transmissions properly.
Porsche Boxster Convertible Top Repair - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 08-06-2016, 10:49 AM   #39
And another set of pages with good instructions:
https://sites.google.com/site/mikefocke2/thetop-itsmaintaince%26replacement
it has not been said here for a while - but the 101 projects for your Boxster Box is a great reference.
Old 08-06-2016, 11:15 AM   #40
2003 S, Arctic Silver, M6
paulofto's Avatar
+1 on 101 Projects, saved me tons of time and $$$$.
