Old 09-21-2011, 05:42 AM   #1
Clamshell Stuck Closed
Ok, passenger side Clamshell is stuck closed and the top is up and won't open. What is the best way to get the clamshell to open manually?
1. Pop off the ball end of the black steel pushrod? I already tried this and it wouldn't budge.
2. Pop off the little clips at the rear of the pushrods?
3. Unscrew the 19mm bolt right in the middle of V lever?
Thanks for the help.
keithl is offline   Reply With Quote
