Originally Posted by peterbrown77
Insite may have a point though - if the microswitch is failing then perhaps it tried to drive the top in the wrong direction and broke your cable...
Well the cable was broken on the otherside. And it turns out the original side i was having trouble with was off the track. I took both sides off, lined up the marks on the transmissions, installed the new cable, adjusted the microswitch so it matched the other side and now it works perfectly. Kind of an adventure, but Im glad it's working.
Thanks a lot! I couldn't have done it without help from you guys.
