09-09-2011, 06:26 AM
#1
Smoke on start up
I have a 01 Boxster 65000 miles, car smokes on start up for about 15 seconds. the shop i use told me i may need an oil seperator cost 850.00. has anyone had this problem and had to replace the oil seperator.
thanks
09-09-2011, 06:34 AM
#2
The AOS is a common issue on these cars, we probably do 6-8 a month at the shop. It is also a common DIY project.
09-09-2011, 08:33 AM
#4
Personally, I would recommend ordering the parts and either do it yourself or bribe a buddy with some pizza and beer.  Here are two more useful links, which detail the process of replacing the AOS.
1975 Porsche 914
1997 Porsche 986
09-09-2011, 05:40 PM
#5
Did you know that an occasional small amt of smoke is "normal" for a Boxster? The boxer engine design is prone to belching a bit of smoke when started. You don't say if the smoke is on every start up or now and then. If it smokes on every start, then the AOS is probably the culprit, but don't be alarmed by the occasional puff.
1989 928 S4 5 spd - black
09-10-2011, 05:48 AM
#6
My car smokes a little about 20% of the time on cold starts. The price of the AOS is only about $150 so they're gouging you on the price they quoted. I bet it doesn't take an experienced mechanic more than 2 hours.
You can give the car an unofficial AOS test by attempting to remove the oil fill cap with the motor running. A bad AOS puts an extreme vacuum on the crankcase and therefore the oil fill cap is hard to lift off.
09-10-2011, 11:33 AM
#7
If you are parked pointing uphill, the puff is very likely.
2001 Boxster, GT3 console delete, lower stress bar, RoW M030 suspension package, painted bumperettes.
09-10-2011, 05:39 PM
#8
Yes. For some reason, if I parked my first Box on an uphill grade, it would smoke for a second on start up. When I changed to backing in to park (when parked outside) it did not do it. Can't say why.
Denver Steve
Carrera, Cabriolet, 6-Speed, Black/Tan
09-10-2011, 08:47 PM
#9
Just replaced my AOS today. One day before I went on vacation in the beginning of August it malfunctioned. Not too much warning. A had a bit of smoke when starting in the week before, nothing too alarming. Then suddenly CROP DUSTER! Lots of smoke and a lousy running engine.
The new AOS was $121 at Pelican Parts, including $3 for 3 day shipping. Great service, thanks!
Putting the damn thing in was a ********************, though. It's not extremely difficult, but the access really, really sucks. I did the whole operation from the top. Supposedly you should be able to get to the AOS from the bottom by reaching through the linkage. However, I think you need chimp arms, my arms were just not long enough. You can do the whole thing from the top but you need to tie some stuff aside to be able to reach in. The main thing in the way is a big black tube. Luckily you can take it apart and tie it away. IMPORTANT, and said by other people before, you need cable operated hose clamp pliers. I got mine from Sears. Forget about doing this operation without these pliers. You need it to release the clamps on the bottom tube of the AOS. Even with these pliers it's very difficult to access these clamps, there is just too much stuff in the way. A little mirror to look underneath the AOS is indispensable, especially to make sure that the bottom tube is hooked up properly.
The whole operation took me about 6 hours, but that's including jacking up the car and deciding not to go that way. I think 4 hours is realistic. Saved myself a couple of hundred of bucks probably. $850 sounds like a ripoff.
Hey, no more smoke! And still a lot of nice, top-down days ahead.
09-10-2011, 12:53 PM
#10
My car does the same on the occasional cold start. It can be discerting the first time it happens but its no big deal (as long as its occasional).
09-10-2011, 01:57 PM
#11
It's kinda like a fart. As long as nobody hears (sees) or smells it there's no harm.
11-28-2011, 07:55 PM
#12
i didn't have a smoke problem, but my cel came up. so i replaced the aos, but now occasionally have the smoke. funny, eh?
-Tuan
tuanle16@juno.com
11-28-2011, 08:34 PM
#13
What made you replace the AOS? Code or just a hunch? Was it a DIY job for you?
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
11-28-2011, 09:27 PM
#14
1128 code came up and i read up on aos. checked the suction seal at oil filler. so replaced the aos. suction better and code went away. but smoke is here now.
it's a pain to DIY. so i went to an indy i know personally. only took him 30-45 mins. but it would have taken me 2-3 hours. difficult to do unless you have the right pliers and a lift. still "do-able" though.
-Tuan
tuanle16@juno.com
12-03-2011, 01:21 AM
#15
I was also under the impression that smoke on start up from time to time was normal (it's in the owners manual). As pointed out, it may be worse when parked at a certain angle or left for more than a few days between start ups.
The way I understand it is that there aren't any oil sealing rings on the pistons (in addition to the compression rings). This allows small amounts of oil to seep past the compression rings over a period of time. The old "K" series BMW motorcycle engines had the same "problem". I can't remember exactly, but you would always get more smoke if it was parked on the side stand (as the oil would drain more freely through into the cylinders) than when it was parked on the center stand. Or it could have been the other way round.
The similarity being that the BMW engines in question have a flat inline 3-4 cylinder engine and the Porsche a flat 6 boxer.
12-03-2011, 04:18 AM
#16
I think they key here is that I am having the sucking from the oil tube when I remove the cap. Can you all clarify that this is a sign to replace my AOS?
Regardless of whether or not my car smokes on startup (Which it only did on 2 occasions since I have had the car for 2 years) I should still get my AOS replaced.
Thanks for the heads up.
Phoenix, Arizona
12-06-2011, 12:34 PM
#17
This may not be quite the same thing but we had a BMW 528 and it developed a fault with the AOS. We'd had it about a year or so when the engine developed a whistle coming from the head area. We were told it was a faulty valve in the AOS and were quoted about NZ$600-800 to fix it. I asked if it was something that needed to be done urgently as we needed the car for a 1000km trip that weekend. I was told that it wasn't really anything vital and that apart from maybe getting a little louder it wouldn't do anything much more than that.
We had the car for about 4 years (60,000 km's)after that and never bothered to get that fault fixed. The BMW agents didn't even bother to bring it up either really.
12-08-2011, 07:55 PM
#18
1999 base
Hi ftor
If you didn't fixed it yet, I will be happy to give you a hand with the job.
I'm located in Fort Lauderdale, and have all the required tools. so just send me a PM if you want.
Thread Tools |
Display Modes |
Hybrid Mode
