05-29-2011, 06:21 PM
Shock or Spring (need help please)
1998 Boxster, 72K:
Really need some help identifying this issue (before I attempt a fix).
Front passenger side (right) noise that sounds like shock or spring. Started hearing fairly loud squeak noise - almost like if you pushed down on a spring bed. Louder when car is moving very slow (then heard less).
Any thoughts??
thanks, Dave
05-30-2011, 06:25 AM
Porsche "Purist"
Wheel bearing?
1987 924S. 2002 996TT. PST-2
05-31-2011, 05:34 AM
Don't think it's wheel bearing. When the car is stopped and not running, if you push down on the front right-side, you can thern hear the creaking noise (and seems to be from the spring or shock area).
05-31-2011, 05:50 AM
the nylon ball joint races are NOTORIOUS for this. there's a simple cure. cut a tiny hole in the ball joint boot & spray in some WD40. problem solved.
05-31-2011, 02:09 PM
Could be one of the bushings, a shock, spring, ball joint, etc. You're going to have to go through all of the suspension components, one by one, to isolate and identify the cause of the squeak.
When I had a similar issue, I put the car on four jackstands and then took the wheel off and used a jack to lower/raise the suspension assy to try and isolate the problem to a particular component.
Maybe someone else can suggest other (better) ways to perform this kind of check.
05-31-2011, 04:57 PM
Wd40= Solvent
WD40 is a solvent not a lubricant. you need to lubricate not wash it away
05-31-2011, 05:33 PM
Class time... Everyone go to [url]www.wd40.com[url] and go to the automotive page.
WD-40 Lubricates, Cleans, Protects, Penetrates & Displaces Moisture... And does so much more!
Jäger
300K Mile Club
05-31-2011, 06:00 PM
That, and the ball joints are DRY bearings. Use the wd40.
06-01-2011, 05:36 AM
How difficult is it to access the bearings??
Novice here - only done some minor projects.
thanks.
06-01-2011, 05:52 AM
very easy. turn your steering wheel all the way to the side. behind the wheel, look for the part in the picture. cut a tiny slice with an exacto knife where i've highlighted in red. put the WD40 spray tube into the slice & give it a good squirt. go for a drive so the WD40 gets evenly distributed & cleans out the nylon.
06-01-2011, 06:05 AM
Thanks much for the help.
Appreciated!
06-01-2011, 08:12 AM
Same thing for the rears if they are noisy?
06-01-2011, 08:19 AM
same procedure front & rear. FYI, i went through so many of these things (replacing the squeaky ones) that i finally got fed up & cut one apart. i tried everything from packing them w/ grease, adding zerk fittings, light lube, etc. Turns out the solution is MUCH simpler. WD40. during this process, do yourself a favor & check for play in the ball joints (i.e. grab the wheel & try to move it in & out or side to side). if there's play, replace the control arm. if there is none, spray away....
06-06-2011, 11:05 AM
The suggested fix worked perfectly.
Thanks again!
06-06-2011, 11:27 AM
glad it worked out. take care.
06-06-2011, 11:50 AM
What to do with the hole after you spray WD40? should it be closed somehow?
06-07-2011, 08:46 AM
I did not close the hole.
Good question though. But seems to be fine.
06-07-2011, 09:21 AM
no real need to close up the hole. it's tiny. since this is a dust boot & not a grease boot, leaving it alone is fine.
09-12-2011, 02:00 PM
I am going to try this tonight. Thanks for the help/advice.
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
09-12-2011, 03:08 PM
I will also try this fix.
