Old 05-29-2011, 05:21 PM   #1
Shock or Spring (need help please)
1998 Boxster, 72K:
Really need some help identifying this issue (before I attempt a fix).
Front passenger side (right) noise that sounds like shock or spring. Started hearing fairly loud squeak noise - almost like if you pushed down on a spring bed. Louder when car is moving very slow (then heard less).
Any thoughts??
thanks, Dave
newjerseydave is offline   Reply With Quote
Old 05-30-2011, 05:25 AM   #2
Porsche "Purist"
Paul's Avatar
Wheel bearing?
1987 924S. 2002 996TT. PST-2
Old 05-31-2011, 04:34 AM   #3
Don't think it's wheel bearing. When the car is stopped and not running, if you push down on the front right-side, you can thern hear the creaking noise (and seems to be from the spring or shock area).
Old 05-31-2011, 04:50 AM   #4
the nylon ball joint races are NOTORIOUS for this. there's a simple cure. cut a tiny hole in the ball joint boot & spray in some WD40. problem solved.
insite
'99 Boxster
3.4L Conversion
Old 05-31-2011, 01:09 PM   #5
Could be one of the bushings, a shock, spring, ball joint, etc. You're going to have to go through all of the suspension components, one by one, to isolate and identify the cause of the squeak.
When I had a similar issue, I put the car on four jackstands and then took the wheel off and used a jack to lower/raise the suspension assy to try and isolate the problem to a particular component.
Maybe someone else can suggest other (better) ways to perform this kind of check.
Old 05-31-2011, 03:57 PM   #6
Wd40= Solvent
WD40 is a solvent not a lubricant. you need to lubricate not wash it away
WRGREENER is offline   Reply With Quote
Old 05-31-2011, 04:33 PM   #7
Jager's Avatar
Class time... Everyone go to [url]www.wd40.com[url] and go to the automotive page.
WD-40 Lubricates, Cleans, Protects, Penetrates & Displaces Moisture... And does so much more!
Jäger
300K Mile Club
Old 05-31-2011, 05:00 PM   #8
That, and the ball joints are DRY bearings. Use the wd40.
insite
'99 Boxster
3.4L Conversion
Old 06-01-2011, 04:36 AM   #9
How difficult is it to access the bearings??
Novice here - only done some minor projects.
thanks.
Old 06-01-2011, 04:52 AM   #10
very easy. turn your steering wheel all the way to the side. behind the wheel, look for the part in the picture. cut a tiny slice with an exacto knife where i've highlighted in red. put the WD40 spray tube into the slice & give it a good squirt. go for a drive so the WD40 gets evenly distributed & cleans out the nylon.
insite
'99 Boxster
3.4L Conversion
Old 06-01-2011, 05:05 AM   #11
Thanks much for the help.
Appreciated!
Old 06-01-2011, 07:12 AM   #12
Same thing for the rears if they are noisy?
Old 06-01-2011, 07:19 AM   #13
same procedure front & rear. FYI, i went through so many of these things (replacing the squeaky ones) that i finally got fed up & cut one apart. i tried everything from packing them w/ grease, adding zerk fittings, light lube, etc. Turns out the solution is MUCH simpler. WD40. during this process, do yourself a favor & check for play in the ball joints (i.e. grab the wheel & try to move it in & out or side to side). if there's play, replace the control arm. if there is none, spray away....
insite
'99 Boxster
3.4L Conversion
Old 06-06-2011, 10:05 AM   #14
The suggested fix worked perfectly.
Thanks again!
Old 06-06-2011, 10:27 AM   #15
glad it worked out. take care.
insite
'99 Boxster
3.4L Conversion
Old 06-06-2011, 10:50 AM   #16
What to do with the hole after you spray WD40? should it be closed somehow?
sasha055 is offline   Reply With Quote
Old 06-07-2011, 07:46 AM   #17
I did not close the hole.
Good question though. But seems to be fine.
Old 06-07-2011, 08:21 AM   #18
no real need to close up the hole. it's tiny. since this is a dust boot & not a grease boot, leaving it alone is fine.
insite
'99 Boxster
3.4L Conversion
Old 09-12-2011, 01:00 PM   #19
97 Boxster's Avatar
I am going to try this tonight. Thanks for the help/advice.
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
97 Boxster is offline   Reply With Quote
Old 09-12-2011, 02:08 PM   #20
I will also try this fix.
SF-Rockster is offline   Reply With Quote
