Old 01-06-2011, 11:40 PM   #1
Cam Cover Oil Leak
My '99 has a small cam cover oil leak. Actually, its more than a seep and less than what I'd call a leak (no drops on the garage floor, but I can see oil under the cam covers). Dealer said to just ignore it unless it gets much worse and said to re-seal the cam covers would be ~$1,000 in labor.
Really? Can someone tell me why re-sealing the cam covers is so time consuming?
I am not talking about taking off the heads, but just removing the cam covers, scraping off the old sealant and cleaning the surfaces, and reapplying new sealant and re-installing the covers. Sounds like ~3 hrs of work, not the 7-10 that I got from the dealer (and I read the same number of hours in various forums).
Can someone who's done this give me a quick run-down in regards to what am I missing or underestimating? When someone re-builds a Boxster engine do they spend 10 hours just getting the cam covers re-sealed?
Old 01-07-2011, 06:32 AM   #2
Your dealer is correct; do not remove the cam covers unless you have a substantial leak (e.g.: dripping). Nearly all cars we see have some evidence of oil “sweating” near the mating seam with the heads, it is completely normal. Removing, cleaning, and resealing the cam covers is not difficult, but it is very time consuming; and quite often results in more problems than it solves. If there isn’t a real issue, leave it alone……………..
Old 03-17-2013, 09:33 AM   #3
I was told that I can pull the Cam Cover bolts out one at a time then either replace or clean exisiting bolts with alcohal then a little permatex on the head and put back in in and make sure I do not over tighten. What do you all think?
Best Regards
Paul
alphaboy1 is offline   Reply With Quote
Old 03-17-2013, 09:57 AM   #4
That sometimes works but only if the leaks are from the bolts, although I would not use Permatex.
Old 03-17-2013, 02:38 PM   #5
Idaho Red Rocket 3's Avatar
What would you use to reseal bolts in this manner ?
2000 Boxster S
Old 03-17-2013, 03:06 PM   #6
Loctite 5900
Old 03-17-2013, 06:25 PM   #7
I had good results by replacing the 3 (4?) bolts along the lower cam cover. I took them out one at a time, thoroughly cleaned the threads going into the head by chasing them gently with a tap, flushing with brake cleaner, then installing the new, micro encapsulated bolTs from the dealer with a good goober of sealant. Don't over torque the bolts!
It's hasn't completely solved the leak, but it went from a persisten drip to a drop of oil every now and then.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-15-2013, 09:17 PM   #8
Ckrikos's Avatar
I sent some pics to my mechanic and he said that I probably have a cam cover leak. Now I don't recall this leak prior to my large service with them. I'm thinking about just replacing the bolts as you guys have done. What's the torque spec for those bolts.
LB/GG/MB 02 2.7 sold
MB/GG 02 996TT
Old 06-15-2013, 09:28 PM   #9
BYprodriver's Avatar
10 ft/lbs make sure you get the correct bolts, 10.9 grade & 30mm long I think
