Old 10-20-2010, 08:15 AM   #1
Foam coming out the air vents?
There's foam coming out of my air vents? It's decintegrated flaky foam. Where is this coming from? I just had my 60K mile maintenance done. Did they miss some sort of in cabin filter?
yellowboxster01 is offline   Reply With Quote
Old 10-20-2010, 08:46 AM   #2
The duct work for your heater tubes under the dash have foam in them where they connect. Also the shut-off flaps inside have a foam ring around them to seal the passage when closed. Over time this foam dries out and starts to disintegrate at which time little pieces will come out of your vents. This happens quicker on cars that are not garaged as they get to sit in the sun and bake.
2000 New Beetle / in search of 03 986S triple black
Caractere kit seam sealed, Caractere rear wing, 1 3/4" drop on coilovers, 235/40/18 Kuhmo XS on 18x8 Millie Miglia Spider II's, H2sport spindles, H&R front Sway bar, O-bar rear torsion, VF Eng. motor mounts, G60 12# flywheel, Nuespeed P-flow intake, Forge DV, Samco IP, Custom K04 turbo and Upsolute chip, 4 bar fpr, TT 2 1/2" SS DP, 2 1/2" custom stainless exhaust no muffler, Peleguin LSD, B&M SS, Momo 14" wheel, R32 steering rack.
yelojkt is offline   Reply With Quote
Old 10-20-2010, 08:51 AM   #3
Yellow:
The foam that helps to seal the various flaps begins to disintegrate at some point in a Boxster's life. There is a straightforward fix, which involves getting access from outside the car, at the base of the windshield, behind the location of the battery. That will give you access to the heater core location and access to the flaps that must be repaired.
There was a very detailed DIY on carboncow.net, but that link doesn't work anymore. Go on RennTech.org and send a PM to "rsfeller" ("Shawn") and ask him for the DIY that he created. He is always very helpful.
Regards, Maurice.
schoir is offline   Reply With Quote
Old 10-20-2010, 10:21 AM   #4
Same issue here, but it isnt too bad.
Highlow is offline   Reply With Quote
Old 10-20-2010, 04:59 PM   #5
I've got it bad in my car. Someone should get that write up and post it in this thread.
Old 10-21-2010, 03:43 PM   #6
jcb986's Avatar
Me too...I call it Black Snow.
Old Hippie Young Heart
Old 10-21-2010, 06:46 PM   #7
I had this problem and did the DIY that was refereed to above. Pretty straightforward. Mine has been fixed for almost a year and a half now and I still have this crap coming out of my vents. I took as much as possible out from the heater box, but I guess some pieces were already in the vents.
I sealed the flap with some metallic tape and then put weather stripping around the edges, followed by another layer of metallic tape. The hot/cold function works very well....I just have to deal with the remnants of that black foam junk for now.
I hope somebody can provide that DIY, it was very well written.
SB
'99 Boxster - Ocean Blue/Graphite Grey
http://i6.photobucket.com/albums/y22...y/IMG_0937.jpg
Scbrindley is offline   Reply With Quote
Old 10-19-2016, 04:47 AM   #8
Luckyed
Luckyed's Avatar
My foam is gray in color.
I assume it has to stop eventually when all the loose pieces eject themselves.
Personally, I don't care if it affects the heater in the car because we live in FL.
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
Luckyed is offline   Reply With Quote
Old 10-23-2010, 12:59 PM   #9
Reggie&Sue's Avatar
I started getting the dried out foam this summer, and just vacuumed out what could from the vents.
If you don't replace this foam does it eventually affect the heater performance ? Being in hot and humid Houston I hardly ever use the heater, but we need heat maybe 10 days each winter.
Reggie&Sue is offline   Reply With Quote
Old 10-24-2010, 09:00 AM   #10
From what I have experienced, it doesn't hurt the heating abilities but what it does affect is the ability to choose which vents you want the air to come from. So if you choose the main vents on the dash facing the passenger/driver, you will be getting some air out of the vents right next to the windshield which suck sometimes because then if fogs up.
Old 10-26-2010, 08:40 PM   #11
Yup, I've got the same problem.... foam coming out of the vents and air coming out of the top vents blowing at the windscreen, even though those vents were not selected.
I tried activating the footwell vents (together with the main vents) which seem to reduce the air coming out of the top vents to a minimum. This way, the windscreen doesn't fog up BUT now I've got cold feet !
I presume fixing the foam at the heater behind the battery won't fix this problem ?? I presume there should another flap somewhere that controls the airflow to the top ?? Hopefully don't have to rip out the dashboard to get at it... hmm.
Having said that, my new E90 BMW blows cold air on the windscreen whenever the a/c is on, and I was told that can't be disabled ! doh...
shlim8 is offline   Reply With Quote
Old 10-18-2016, 02:25 PM   #12
Was there ever a fix to this? I fixed the blend door that mixes the cold and warm air, but I have not seen anything about the door that directs the air to the upper, lower and middle vents.
nbeihl is offline   Reply With Quote
Old 10-19-2016, 12:38 PM   #13
1999 base
Meir's Avatar
you have two options.
the short:
https://www.scribd.com/doc/212147792/986-Heater-Flap-Repair-Boxster-foam
and the long:
A/C evaporator replacement-A/C foam flakes
