The duct work for your heater tubes under the dash have foam in them where they connect. Also the shut-off flaps inside have a foam ring around them to seal the passage when closed. Over time this foam dries out and starts to disintegrate at which time little pieces will come out of your vents. This happens quicker on cars that are not garaged as they get to sit in the sun and bake.
2000 New Beetle / in search of 03 986S triple black
Caractere kit seam sealed, Caractere rear wing, 1 3/4" drop on coilovers, 235/40/18 Kuhmo XS on 18x8 Millie Miglia Spider II's, H2sport spindles, H&R front Sway bar, O-bar rear torsion, VF Eng. motor mounts, G60 12# flywheel, Nuespeed P-flow intake, Forge DV, Samco IP, Custom K04 turbo and Upsolute chip, 4 bar fpr, TT 2 1/2" SS DP, 2 1/2" custom stainless exhaust no muffler, Peleguin LSD, B&M SS, Momo 14" wheel, R32 steering rack.
