10-05-2010, 10:10 PM
IMS Install Issues?
Got the LN bearing and clip thing installed into the car tonight but cant figure out how to finish.
I cant seem to get the final part on becasue the entire assembly where the bearing is installed has shifted upwards a little. Tried to tug it down a little but No luck with that. How can I get this thing lined up straight again?
I did also remove both cam chain tensioners also.......which apparently I was not suppose too do.........dammit!
Well one article said to remove tensioners completely and the other article I read said to only back them out half-way or so......... I chose to remove them
I thought both cam tensioners where the exact same but after looking closer at them they are different. Anyone know which one goes on which side of the motor? I mixed them up and dont know which goes where now? One does have a slightly larger end on it.
What do I do now??
Pic attached
10-05-2010, 10:13 PM
I guess the pic didnt attach
Pretty much the tube that the bearing sits in shifted upwards and I need it to be centered in-order to get the final piece(cap thing) on
10-06-2010, 05:46 AM
I think I would call Charles at LN immediately...I believe I've read in the past you've likely jumped timing and now have a real project at hand.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
10-06-2010, 07:21 AM
God I hope not??
10-06-2010, 07:41 AM
don't stress; you'll get it sorted. what year is your car? i'll assume it's an early one.
first, there are actually three tensioners. there's one on each head and one on the block. find the third one and remove it.
it sounds like your IMS is just caught on the block a bit. try tapping the flange gently with a plastic hammer & see if it pops into place.
the tensioners ARE different. look at the top of each one. each has a hole in the center. one has no rings around the hole, another has one ring around the hole, and the last has two rings around the hole.
no rings: bank 4-6
one ring: engine block
two rings: bank 1-3
get back to us w/ the year & we'll go from there on engine timing.
10-06-2010, 07:44 AM
okay, i just saw in another thread that you have a '97.
now we need to check the timing. set your engine to TDC. on each head, there should be one side w/ two green plugs and another side w/ one green plug on the camshaft ends.
on the sides w/ two plugs, pull the lower plug out (exhaust cam). the notches in the ends of the cams should be perfectly vertical. if they're off significantly, you'll need to re-time.
i plan on posting that procedure later today w/ photos.
10-06-2010, 07:51 AM
thanks Insite
if you look at figure 97 in the link, it shows the thing off-centered also in the DIY. with it off-centered I just cant imagine how to get the cap on.
http://www.pelicanparts.com/techart...aft_Bearing.htm
So I should remove all 3 cam tensioners on a 1997 boxster? the DIY articles only mention removing 2?
10-06-2010, 07:56 AM
Originally Posted by dirkdiggler
thanks Insite
that link isn't working for me. go ahead & remove the 3rd tensioner. it won't hurt, & may give you some wiggle room.
10-06-2010, 07:58 AM
Engine Surgeon
Sounds like you didn't have the engine locked at TDC #1 cylinder... if you did not the cam timing MUST be re-set because it has been compromised. This is the first procedure that must be done, but no one seems to listen to that.
Its not as simple as putting the engine back at TDC, locking it and going back together with it.
If the IMS tube shifts, there is a reason, some camshaft is "on lobe" and is exerting force on the IMS tube, EVEN WITH THE TENSIONERS REMOVED!
Tensioners are marked per position with rings that match the casting rings that are embossed on the heads.
This procedure must be carried out explicitly with great attention to detail, you can't just pull things apart and expect the process to go smoothly on reassembly.
US Patent 8,992,089 &
US Patent 9,416,697
10-06-2010, 07:59 AM
were is the third located exactly? I removed the 2 off the heads but didnt recall seeing a third one to be honest.
I did have the motor set at top dead center.
10-06-2010, 08:00 AM
did you lock to TDC prior to beginning?
i found the pic. if yours looks like that, you're probably in good shape. i'd put the flange on & hand thread the nut into place. start the 3 flange bolts & they should center the IMS
10-06-2010, 08:05 AM
yes I had it set at TDC prior to starting this procedure.
I didnt have the cam locking tools though.
Pic attached of my issue
as you can see it is not centered which doesnt allow me to install the cap thing.
is the Flange the part that I keep referring to as the cap? Im not sure I can start threading the 3 bolts if its off-centered?
and where is the third tensioner located?
The crappy thing about all this is that the bearing I pulled out of the car was mint and dont think I even needed to install this new IMS .......... oh well
10-06-2010, 08:49 AM
if you're looking at the IMS, the 3rd tensioner will be located by the oil pan, pointing to the left side of the car. it's on the crankcase rather than the heads.
10-06-2010, 08:50 AM
when you set TDC, did you lock the motor? i know you said you don't have the cam locking tools, but did you lock the crank?
10-06-2010, 09:00 AM
I did not lock the motor, just set it at TDC.
While Looking at the IMS:
I removed a tentioner that was directly to the left of the IMS pointing directly out the left side of the motor.
I also removed the tensioner on the right of the motor that points straight downward towards the ground.
Im just wondering if I didnt even remove the correct 2 I was suppose to at this point?
This is a huge stressful nightmare! uggghhhh
10-06-2010, 09:12 AM
you missed the one on the other head; it points upward.
looking at your picture, i wouldn't even bother pulling the other tensioner. i think your flange will install just fine as-is.
10-06-2010, 09:18 AM
oh, and check to see if you're still at TDC. if you are, slide a bolt through the OT hole on the front pulle to lock it. if you're not, do NOT turn the front pulley until you have the flange in & the tensioners reinstalled.
BTW, where are you located?
10-06-2010, 09:19 AM
I just dont understand how it will install if it isnt centered though and doesnt have any play allowing it to move back too center while installing.
I can get the flange around the shaft in the middle of the bearing but it will not slide in like it should becasue the flange hits the motor becasue everything isnt centered properly.
So.....removing the last tentioner will not allow any play so I can center this thing?
10-06-2010, 09:31 AM
hmm. you can try the last tensioner. it's at the other side of the motor & would have less of an effect, but it may be worth a try. see if you can lock the crank first.
if the lip of the IMS flange isn't making it past the case fairly easily, don't forces it....
Engine Surgeon
The IMS is being lifted because the engine has a camshaft "on lobe" producing load on the IMS tube. This is not a tensioner issue. If the crank is not locked at TDC the entire job is compromised from the beginning.
I offer consulting when these issues occur, it is not cheap but I can help.
US Patent 9,416,697
