Old 10-05-2010, 10:10 PM   #1
dirkdiggler
IMS Install Issues?
Got the LN bearing and clip thing installed into the car tonight but cant figure out how to finish.
I cant seem to get the final part on becasue the entire assembly where the bearing is installed has shifted upwards a little. Tried to tug it down a little but No luck with that. How can I get this thing lined up straight again?
I did also remove both cam chain tensioners also.......which apparently I was not suppose too do.........dammit!
Well one article said to remove tensioners completely and the other article I read said to only back them out half-way or so......... I chose to remove them
I thought both cam tensioners where the exact same but after looking closer at them they are different. Anyone know which one goes on which side of the motor? I mixed them up and dont know which goes where now? One does have a slightly larger end on it.
What do I do now??
Pic attached
dirkdiggler is offline   Reply With Quote
