Old 07-08-2009, 09:15 AM   #1
Plastic Window Cracked - cheap fixes?
This morning, headed to work and the weather was nice, and I wanted to drop the top. I opened the top, started opening it, and I normally stop it about 1/2 way to get out and "chop" my plastic window to fold it nicely...
before I even got to 1/2 way, I hear a "pop/crack" sound. I get out and look at the window and see that it has cracked. The edge portion, millimeters from the seam/stitching on the border of hte window cracked - it's not that visible as it's only about 2" long, it's parallel to the seam, and immediately next to the seam...so it's somewhat hidden...but I know it's only a matter of time until it spreads and becomes an eyesore.
My top was replaced a couple years ago, so the canvass portion is perfect. I really don't want to go spend a couple grand for a new top just to fix the plastic window.
Years ago I owned a Miata that also had a plastic rear window that did the same thing and a local upholstery shop was able to remove my plastic window and stitch a new one in for like $250. it looked OEM. I'd much rather suffer with another plastic window if I can replace it this cheap vs buying a whole new top for several thousand.
anyone successfully do that on the boxsters?
23109VC is offline   Reply With Quote
Old 07-08-2009, 11:11 AM   #2
Been there, did the fix myself with a kit. It is a lot of work, much more than I had anticipated. I would recommend you find a shop willing to stitch in a new window with the canvas still on the frame. The entire convertible top (canvas & frame) is surprisingly easy to remove. Most shops want to remove the canvas from the frame, that is where it gets expensive.
See also:
DYI rear plastic window.
Cracked Plastic
Replacing plastic back window '01 Boxster's Top
If your on Renntech I sort-of took over another thread about a top, there are a couple pics there as well as some discussion of the process:
http://www.renntech.org/forums/inde...287&#entry94287
I used a clear silicone caulking as a temp fix till it got too bad and ghetto looking.
kabel
kabel is offline   Reply With Quote
Old 07-08-2009, 12:03 PM   #3
UPDATE-
I called a local upholstery shop that has been in San Diego for years and years - they quoted me $275 to restitch the plastic window. they said they can get me tinted plastic for another $30 but they have to special order it as they don't normally stock that... so $300. they said it takes less than a day.
they said they do NOT take the top off the frame. they remove the top from the car and do it while it's on the frame.
they said they can upgrade to a glass top window - I dind't ask if it was GAAH or some other brand - but the cost to convert to an all new top with glass - $1425. that is a total cost including labor.
so essentially i'm looking at an extra $1000 to go to glass. i'm almost tempted to go to glass b/c I HATE the chop. I would LOVE to be able to jump in the car, fire it up, drive off, and then just put my top down as I'm cruising at 5-10mph... I've got that fuse hack so I can raise/lower the top while rolling after just clicking the ebrake up one little click..but I NEVER do it to lower the top b/c I can't properly fold the window..I do it all the time when raising the top and it's soooo convenient.
decisions decisions...
Old 07-08-2009, 12:23 PM   #4
Try a marine canvass shop, some are even mobile and tow their equipment. They are used to working with what they call glass (the clear plastic) and mating it with canvass in just about every way one can imagine.
Old 07-08-2009, 01:59 PM   #5
I just posted this in another thread.
I installed the GAHH top with the acoustic material and glass rear window. Its a HUGE improvement. Well worth the money. You can actually see out the back. But the biggest surprise is how quiet the car is with the acoustic material. Its so quiet that now I can hear all the rattles that I never heard before.
fatmike is offline   Reply With Quote
Old 07-08-2009, 03:10 PM   #6
what did you pay for your top and what did you pay for install? or did you DIY??
can you see any major difference in the top vs your OEM top or is it something "invisible" that you can't see from inside the car looking up at the top while closed??
my canvass top was replced a couple years ago by the dealer under warranty by the former owner. why they didn't covert to a glass 03-04 top I don't know - maybe the part was more mney, maye the warranty wouldn't do it..i dunno... but my canvass is VERY clean. It would be hard to justify going to glass for all the expense JUST to get glass... although believe me, I want to...
$300 vs $1500..... arrgghhhh...
i'm about to buy another car too...my current DD took a crap and I had to sell it. I'm back in the maket for antoher car AND found out my work is cutting pay for 7-10% due to the "economic crisis"....so shelling out "extra" money might not fly well with my CFO / wifey.
honestly... for a car i only drive on weekens...I honestly coudl live with a new plastic top - as long as it turns out nice. but glass would be nice!
