Old 01-14-2009, 09:03 AM   #1
Flashing CEL
I don't think this is anything major and may be just a computer glitch, but I wanted to see if any other owners have experienced this. On a few occasions the CEL has flashed for 5-10 seconds then gone away. It happened once or twice a few years ago and then it didn't do it again until the other day. Like I said it was only for a few seconds so I didn't even have time to pull over and investigate. Engine seems to run fine and I've driven it a couple times since with no problems. I'm still under warranty so I'm not too concerned, but at the same time I know flashing CEL's aren't a good thing usually. Anybody else have a similar experience? Thanks in advance.
Old 01-14-2009, 09:24 AM   #2
TriGem2k's Avatar
Send a message via AIM to TriGem2k
Adam,
I've had the same thing happen a few times in the last 7 years of owning the car. Exactly as you stated, the light would flash for 10seconds or so then go away and nothing seems wrong with the car.
I asked the dealership about it once while in warranty and once after warranty expired and they said that it could possibly just be a bad batch of gas the car didn't like.
Mine hasn't done it in well over a year now.
If you do figure something out as I haave always been courious as to why they do that. Hopefully others will chime in as well.
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
Old 01-14-2009, 10:17 AM   #3
FTD
I had it happen once at a track. Somebody had a reader. Misfire on 2 cyclinders. Cleared the codes and it never happened again. Theorized to be result of too much oil. I now fill to about a half quart below full.
Doesn't the CEL trap a code or two when it comes on, that you could then read?
Old 01-14-2009, 12:36 PM   #4
Had it happen to me last spring after hibernating for a couple months. I had a misfire on cylinder 2 and additionally cylinder 3 on two separate occasions. So, since my ride was due for its 60K maintainence anyway, I decided to just replace all my plugs, coils and tubes. Also helped that I had a few guys on renntech help me out with suggestions of a bottle of Techtron and an oil change. Ran fine after resetting the codes.
dcporsche99 is offline   Reply With Quote
Old 01-14-2009, 12:45 PM   #5
That's a good question. I didn't know if it would be worth the while if there isn't anything lit up on the dash.
Old 01-14-2009, 01:17 PM   #6
FTD
Some auto parts places will plug a reader in for you and pull the codes. However, I don't know all details as in the CEL in my 11 year old Honda came on [and stays on] and I was told it doesn't write to a log file when that happens. It is a general warning re: fuel/air based on 3 or 4 sensor points. So, maybe yes [like my 04 Porsche] and maybe no [like my '98 Accord].
Old 01-15-2009, 04:08 PM   #7
Porsche "Purist"
Paul's Avatar
Have the codes read.
I think every Boxster owner should consider purchasing the Durametric tester. Even if it keeps you from going the to dealer once, it's paid for itself in my opinion.
1987 924S. 2002 996TT. PST-2
Old 01-17-2009, 08:19 AM   #8
Thanks for your responses guys. Doesn't sound like anything serious which is good. Paul, the light is no longer flashing, are you saying a durametric tester or scan tool can still tell me what caused it to do so? If so, are the codes date stamped by the ECM? Otherwise how do you know which code occured when? I think the ECM logs things in run time hours no?
Old 01-17-2009, 08:26 AM   #9
Porsche "Purist"
Paul's Avatar
Yes the codes are stored until cleared.
Old 01-17-2009, 08:30 AM   #10
Ok, thanks for the info. I will have the computer scanned especially if it keeps occuring.
