Old 02-19-2008, 06:44 AM   #1
clutch failure
Hi everyone,
a funny thing happen on my 2001 yesterday. After driving around all day and the clutch feeling funny during decompression, it finally blew. The pedal went suddenly easily all the way down and stayed there! I could retract it and push it again. No hydraulic behind it.
It stayed half-way decompressed once 2000 miles earlier. After 20 minutes stop-and-go on a hill side.
Just thought I'd share this warning sign.
miles is offline   Reply With Quote
Old 02-19-2008, 08:59 AM   #2
this isn't a clutch failure, but a failure of the clutch hydraulic system. it's most likely your slave cylinder and POSSIBLY your clutch master cylinder.
insite
'99 Boxster
3.4L Conversion
Old 02-19-2008, 11:14 AM   #3
Insite is right, either your Clutch Master Cyclindar is gone or the Clutch Slave Cyclindar is gone... Either way its a hell of alot cheaper to replace than a clutch.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 02-19-2008, 02:01 PM   #4
clutch failure
You're right. The master cylinder is gone. The stealership told me, the pedal mechanic needs to be upgraded as well. $200 parts - $800 labor. Roughly :-(.
Old 02-19-2008, 03:31 PM   #5
Porsche "Purist"
Paul's Avatar
Run away, $800 labor is ridiculous!
1987 924S. 2002 996TT. PST-2
Old 02-19-2008, 03:59 PM   #6
Porsche "Purist"
Paul's Avatar
$70 HERE with shipping!
Old 02-20-2008, 09:22 PM   #7
Clutch failure
OK. Finally, it wasn't one of the cylinders but the spring. So sad the towing to this stealership was for free and towing to a real mechanic would have almost cost me the difference anyway.
The bottom line was $700 (including parking brake adjustment. But that's just mentioned to make me feel better )
Old 02-20-2008, 10:13 PM   #8
Lil bastard's Avatar
It's often recommended when replacing either hydraulic component of the system (master cylinder / slave cylinder) to replace them both at the same time.
This is because the old part receives added resistance from the new, stronger part and will usually fail in short order.
It does add slightly to the expense, but you save on having only 1 tow and only need to bleed the system once. This also makes the system work 100% new again.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
