Old 11-17-2013, 09:00 AM   #1
Registered Boxster abuser
healthservices's Avatar
oil leak so I removed the trans....
It looks like I have a RMS leaks but I like to take a peak at the IMS. Can I just remove the cover or do I need to lock it in place and mark everything to remove and reinstall the cover?
Thanks for the advice and info...
Allen
Old 11-17-2013, 09:17 AM   #2
Theoretical propagandist
Eric G's Avatar
If you want to pull the IMS plate, you MUST lock down everything unless you are looking to part out your engine components...period.
Old 11-17-2013, 09:22 AM   #3
Beginner
Jamesp's Avatar
+1 with a bullet. Otherwise bad things are likely to happen.
Old 11-17-2013, 09:48 AM   #4
Bummer more labor.
So
1. Remove the IMS cover bolts, rotate motor until holes in the ims holes are solid and insert set screws to hold IMS in place
2. Remove front engine compartment access door, remove the upper cam plugs, mark their placement with a marker.
3. Remove IMS cover.
4. reinsert cover when satisfied or replace bearing as per instructions.
Old 11-17-2013, 09:58 AM   #5
thom4782's Avatar
Nope...you'll need to lock the cams in place. Follow the 1st part of the IMS replacement instructions up where it tells you how to remove the flange. PS: If you've gone that far, you might as well replace the OEM bearing with an aftermarket one since you'll have done most of the work anyway in getting to the bearing.
Old 11-17-2013, 12:07 PM   #6
How do i go about locking the cams?
Actually this one is not one of my cars. Its for a old forum member (who I will not name) who is on a tight budget.
Yes I recommended it to him, no, as long as it is not leaking or obviously failing he will not do it or the clutch even though it is this far apart.
We all have our limits as to what we can afford. He has set his.
Old 11-17-2013, 03:23 PM   #7
I would recommend reading the various technical articles about IMS bearing replacement on here, and pelican parts before you tackle the job. Or better yet have someone who's done it before do it or at least help. Especially since it's someone else car....if they're on a tight budget they will hate buying a new engine (ask me how I know)! Good luck!
2001 Boxster S 6speed- weekend warrior
2015 Explorer Sport- New DD
2011 Taurus SHO- Sold
2010 CBR1000RR- Sold
Wilson01S is offline   Reply With Quote
Old 11-17-2013, 03:43 PM   #8
Start with this: http://www.imsretrofit.com/wp-content/uploads/2012/12/imsretrofit.pdf
You are going to need some special tools (cam locks, TDC pin, etc.) in order to do this, and you need to follow the above instructions to the letter except for pulling the bearing, which I would also strongly recommend doing as well as you will be 80% of the way there when you stop otherwise.
Old 11-17-2013, 04:40 PM   #9
Beginner
Jamesp's Avatar
Bummer more labor.
So
Stop it you're scaring me........ This is one of those operations that go horribly wrong (timing slips) and you cannot back out. The nightmare scenario, engine failure. If you go in, plan the entire operation end to end (including contingency bearing replacement) using published directions on doing it or leave it alone. No surprises, no real time learning. If you find the bearing is loose, will you change it? Then why not source a 6204 for a few bucks and plan on changing it out in kind if you go in? You can get another NSK or pick another manufacturer.
Old 11-17-2013, 04:48 PM   #10
I think Ben Franklin said "penny wise and pound foolish."
evomind is offline   Reply With Quote
Old 11-17-2013, 05:20 PM   #11
Beginner
Jamesp's Avatar
It's a budget thing...
Old 11-17-2013, 06:31 PM   #12
Well this is a 2001 model and I believe it is a double roller, Will two 6204 bearings fit? what is the alternative option?
If there is one maybe I can offer it to him.
Old 11-17-2013, 06:34 PM   #13
And yes when there is no money to spend and it is the only car you have to drive... There are not a lot of options.
Old 11-17-2013, 06:51 PM   #14
kjc2050's Avatar
If it's an '01, it likely has a single row IMS bearing.
Old 11-17-2013, 07:37 PM   #15
The cover looks pretty shallow ins't this a indicator of whether I have a single or double roll bearing?
Old 11-18-2013, 06:09 AM   #16
That is a dual row set up.
Old 11-18-2013, 06:59 AM   #17
Thats what I was afraid of. Is there a inexpensive alternative in the bearing market that I can use?
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Old 11-18-2013, 07:16 AM   #18
Sorry, but I do not believe in using the cheapest bearing available in an application that could end up costing you $15K+ if it fails.
Old 11-18-2013, 07:22 AM   #19
Just looking for alternatives for the guy. Its not all good times for everyone.
Old 11-18-2013, 07:45 AM   #20
Eric G's Avatar
You have a PM...
