Old 06-05-2012, 12:43 PM   #1
Transmission Oil
Changing oil in Transmission on my 2000 boxster S. Any recommendation on what oil to use? Any tips?
Jim M. is offline   Reply With Quote
Old 06-05-2012, 01:19 PM   #2
Search is your friend, but many recommend to only use Porsche approved gear oil.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-05-2012, 02:10 PM   #3
Was ready to do mine this last weekend until I found out it took a VERY special 16mm triple point security driver to get the drain plug out... had to order that from eBay so now will wait until this weekend to do.
Leeper is offline   Reply With Quote
Old 06-05-2012, 06:22 PM   #4
Jager's Avatar
Yep, you will need a tamper resistant triple square (12-point) to remove the drain plug and a 17mm Allen socket (for 5-speed) or a 10mm Allen socket (for 6-speed) to remove the inlet plug on the side of the trans-axle. I recommend using the Porsche oil, I have also used Royal Purple but the Porsche oil is much better.
Jäger
300K Mile Club
Old 06-06-2012, 06:11 AM   #5
Crazy Austrian
harryrcb's Avatar
After trying several different brands of gear oil in my 04 S , I found the Porsche gear oil works the best.
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
Old 06-09-2012, 02:33 AM   #6
so you can feel the difference between different brands of 75w-90 then
whitecliffs is offline   Reply With Quote
Old 06-09-2012, 07:06 PM   #7
Steve Tinker's Avatar
Yes.......
Just like the Porsche coolant, its worth the extra $ every time !!
2001 MV Agusta F4.
Old 06-10-2012, 07:26 AM   #8
Crazy Austrian
harryrcb's Avatar
Absolutely
Crazy Austrian 007
Old 06-10-2012, 09:20 AM   #9
Moderator
I have heard of other forum members having success with swepco 201. I shall be putting that in when I drain the transmission, but I don't think you could go wrong with OEM Porsche oil.
Old 06-10-2012, 08:23 PM   #10
Crazy Austrian
harryrcb's Avatar
when I used Swepco for a DE weekend I had trouble shifting when it got hot. Just did not want to go in gear after a while. Switched right back to OEM and all that went away.
Crazy Austrian 007
