Old 08-26-2011, 03:37 PM   #1
Fabspeed Bypass Pipe-Any Experiences Welcomed.
Hi Guys,
I have a 2002 Boxster S and I thinking of installing a Fabspeed secondary cat bypass pipe. These pipes eliminate the secondary cats. I would like to just use the Fabspeed Bypass Pipes and still use the stock 986 2002 Boxster S stock muffler.
I wondered about the new exhaust sound, if any, and how it may compare to the stock sound with the secondary cats.
Also, do you think there would be any noticeable increase in HP.
All comments will be very much appreciated.
986NY is offline   Reply With Quote
Old 08-26-2011, 07:33 PM   #2
Johnny Danger's Avatar
Originally Posted by 986NY
Hi Guys,
This topic has been commented upon ad infinitum. In any case, there's no real horsepower to be gained by simply eliminating the secondary cats . However, it will reduce a fair amount of unnecessary back pressure, and give your vehicle a slightly more aggressive sound. Perhaps, most importantly, it will shed a significant amount of weight . And that in and of itself can have it's performance advantages .
Old 08-27-2011, 08:35 AM   #3
seeing as johnny you are the exhaust guy as it were, how do u feel about a full cat-less setup with a stock muffler? (sorry I dont mean to hijack.)
Old 08-27-2011, 10:52 AM   #4
I just did this mod a few weeks ago, only the pipes, everything else stock. Sound is deeper, not huge difference, but better. Thebcar feels like it breathes better, revs quicker, so may seem like more hp, bu not sure. One of my cats were startingnto deteriorate, so the my hve been partially clogged, but either way, now, the car seems to run better and rev quicker.
dennis is offline   Reply With Quote
Old 08-27-2011, 11:50 AM   #5
Based on my experience, you'll lose a significant amount of low end and mid range torque.
Not to mention CEL's galore . In addition, the oem muffler is extremely restrictive . Personally, unless your budget will allow you to purchase a set of high quality headers and cats, I would stick with the oem headers/pre-cats , delete the secondaries, and replace the oem muffler with a suitable aftermarket one . There are numerous brands across a wide price spectrum that will not only weigh considerably less, but will provide better exhaust flow and sound superior .
Old 08-27-2011, 12:41 PM   #6
See my sig.
I am running completely catless and have not had issues, but retaining the stock muffler would not be good. I chose to purchase an oem Eisenman built PSE and the sound is really nice. That version will fit up to MY '02.
As far as aftermarket headers, I chose Turbowerx and they deliver results. You need to find a good indy mechanic and he will know how to keep your O2 sensors from triggering a CEL. It can be done.
I have had only one CEL after having my setup for a year. I purchased the Durametric cable, downloaded 6.0 software and it was gone in seconds..
To get good results, you need to take the plunge and do all exhaust replacement from the headers to the muffler. Just don't buy junk or you will not have a good experience...
All in all, I have 800 in headers, 500 for the Fabspeed pipes, and I think around 13-1400 in the PSE. Bought it new off Ebay a long time ago. They sometimes surface...If not, they can be had close to 3k now, but other manufacturer's like Fabspeed make a good muffler.
I have not run my car on a dyno, but can tell you that additional power is being made. Sound is very nice too.
'13 S - Guards Red / Luxor Beige - Options - Loaded to the Hilt!!
'01 S - Guards Red / Beige - Surrendered - 04.18.12
jwade is offline   Reply With Quote
Old 08-27-2011, 01:04 PM   #7
Originally Posted by jwade
See my sig.
With all due respect, the additional power that you are experiencing must be in the upper rpm range . Clearly, your system is more characteristic of how track applications are set-up, wherein the concentration is much more focussed on high end power. Virtually every boxster that I know (most importantly my own), lost low end to mid range torque when run completely catless . Furthermore, with that set-up the only way that I'm aware that one can truly rule out CEL's is to re-map the ECU. And, that comes with it's own separate cost .
Old 08-27-2011, 02:21 PM   #8
Luckily I have a ROW tune on my car. My only issue that I have is purely sound. I have a deluboz v1 muffler which is nice and light but with the cat-less setup (ebay headers [which by the way seem to be built fairly well and are wrapped.]) and my own made bypass the whole thing is just too raspy and well I think too low on the back pressure. I was hoping adding an S muffler I might increase some of the back pressure and possibly gain some of the lost low end power... but idk if it works like that. I also put on a very small UDP from precision chassis works for good measure.
Old 08-27-2011, 02:36 PM   #9
One day I would like to put the car on a dyno and see what kind of numbers come about.
And yes Danger, the only "fool-proof" way of doing away with the CEL is to reflash with one of the many flavors of aftermarket or RoW software out there.
Wicky Lawrie - 615-226-4928, Owner of Renntag Motorsports, Nashville, Tn [I]was able to defeat the CEL for nearly a year with the install of the headers...
I was shocked too when he said he could do it, especially after reading these forums for so long, but this guys ROCKS!
Anyone near Music City USA needing Porsche service needs to call this man! He knows his craft and is not expensive. You may have to leave it with him a week or two, but it is worth it! And cash is king...
Old 08-31-2011, 03:19 PM   #10
I'm new to the forum and this my first post. I am considering doing the exact exhaust mod you just described on my 2003 986. I'm looking at the Fabspeed Maxflow exhaust system with the 2ndary cat delete pipes and a performance muffler. I'm also researching the FVD Brombacher "Sound Version" muffler with the secondary cat delete pipes. However, after reading some of the posts on other threads about in-cabin drone and resonance, I'd like to be able to meet another member who has already done either mod and hear their car in person. I live in Laguna Niguel, CA (Orange County). If anyone with the mods lives in Southern Cal I'd love to meet them and check out their mods. Please send me a PM. Thanks.
Marburk is offline   Reply With Quote
Old 09-02-2011, 08:36 AM   #11
There are youtube videos of the Fabspeed Exhaust sounds from inside the car and outside. You can access them from Fabspeed.com when looking at the products, or you can go to youtube.com and manually search them.
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
Old 09-02-2011, 11:59 AM   #12
the effect of the bypass pipes on sound largely depends on your muffler. with a reasonable muffler, the sound is deeper & more throaty. in my car, which has a race muffler and no sound deadening, the exhaust is MUCH louder with the bypass pipes; more like a cup car.
that having been said, i have an extra set of brand new T304 stainless bypass pipes i'd be willing to part with. caveat: they are designed to work with mufflers that have a larger 2" inlet rather than 1.75" like OEM. i will post a pic later.
PM me if you want them; they could be necked down like the fabspeed pipes pretty easily. $300 for the pair.
insite
'99 Boxster
3.4L Conversion
Old 09-02-2011, 01:38 PM   #13
The Radium King's Avatar
do the ebay headers and leave the stock mid-pipes/cats. that's how porsche does it in countries with less strict emmissions requirements.
north america has the added requirement for emmissions reduction at start-up, so american cars have an additional warming 'pre-cat' on the headers and a secondary air pump, as well as sensors and ecu programming that checks to make sure both are working. row does not have this requirement, so row cars do not have cats on the headers or secondary air pumps, and no sensors to confirm their operation.
you can get catless, equal length, stainless headers on ebay for $65; the cheapest you can get new catless midpipes is $500. get headers without cats, however, and you have to deal with the sensor that is there to confirm the operation of the now-absent cats (or you get a 'check engine light'). you can reporgram your ecu to row, you can buy 'foolers' (fvd sells them) or you can make your own. all the sensor does is look for 02 content in the exhaust. it can be fooled into thinking that the cat is working by distancing it from the exhaust; some guys just hang it under the car, or you can get spark plug savers that thread into the exhaust bung and get the sensor out of direct exhaust flow (make sure your new, catless headers have two bungs each). there is also supposed to be a trick that uses a resistor or diode wired into the sensor; google is your ally for cheap, easy solutions to this.
other considerations are pipe diameter; oem for a 3.2 is 1.25" into 1.75" (ebay headers vary, but 1.5" into 2" is typical); go much bigger than this (or go completely catless or to a high-flow muffler) and you get into backpressure issues. reduced back pressure is good at high rpm when the engine is trying to flow as much air as possible, but at low to mid-range some back pressure is necessary to facilitate combustion chamber scouring and make max power. i've yet to see a dyno of just a high flow exhaust that does not indicate a drop in hp/torque at lower rpms. that's why most dynos from tuners include ecu flashes to compensate or don't start until 3000 rpm to hide this fact.
other things i've read is that cats tend to kill high frequencies, so a catless exhaust can be ricey sounding. also, i've read that those who have compared row to us spec cars have found the row to only be several hp stronger, so better figger out what your $/hp threshold is. i can justify $65 for several hp; uncertain if i can justify $500 for the same gain.
ps - lobo; what's the word on the wrap - worth it? keeping things cooler at all?
Old 09-02-2011, 06:18 PM   #14
With all due respect, at 600 cells the secondary cats are arguable the most restrictive (and possible the heaviest) part of the oem system . Therefore, if one is going to leave most of the system intact, it would be far better to leave the headers/pre-cats in place and remove and bypass the secondaries .
Old 09-02-2011, 06:27 PM   #15
True. Plus, no cel with properly built pipes. The secondary cat pipes weigh close to 30 lbs. The bypass pipes? 8 lbs.
Total weight savings on my full exhaust was about 80 lbs.
[B]With all due respect, at 600 cells the secondary cats are arguable the most restrictive (and possible the heaviest) part of the oem system . Therefore, if one going to leave most of the system intact, it would be far better to leave the headers/pre-cats in place and remove and bypass the secondaries . [/B]
insite
'99 Boxster
3.4L Conversion
Old 09-02-2011, 06:54 PM   #16
weight aside, the argument becomes where the remaining cats are located for best performance - on the headers or on the mid-pipes. porsche and cost say delete the cat on the headers.
changing mid-pipes is easier; no potential seized bolts in the block, no sensors to deal with. however, here are some links to three easy ways to fix the cel issue:
http://forums.evolutionm.net/evo-how-requests-questions-tips/215795-5-o2-cheater-non-fouler-how.html
http://www.fvd.de/us/en/Porsche-0/-/-/-/item/item_details/VID_33179399-VCD_85527367-gid_29-sort_4-display_50-item_FVD111LAMVER/EXHAUST_-_Tuning_-_Catalytics-FVD111LAMVER-Oxygen_Sensor_Extension.html
http://www.audiworld.com/tech/eng53.shtml
otherwise, everything i find on the intraweb says that the pre-cats are more restrictive than the main cats ...
Old 09-03-2011, 05:30 AM   #17
Ideally, if one could eliminate the oem header/pre-cat design in favor of a set of high quality aftermarket headers that incorporated both larger diameter and longer equal length primaries that flowed into a well designed merge collector, along with a pair of high flow cats (something on the order of 200 cell tri-metal HJS or Emitec cats) that were located mid stream - that would prove to be a very effective system indeed. However, in order to accomplish something along these lines, one would have to spend big buck$$ ! Especially, with the cats . Having said that, unless a person's budget would allow for this kind of expenditure, the best option would be to remove and bypass the secondary cats. The 986 boxster shares the same secondaries as 996 platform vehicles. And, at 600 cells, these cats are much more restrictive (and heavier) than the pre-cats which are 400 cell .
Old 09-03-2011, 11:01 AM   #18
the ebay headers are copies of expensive headers (slightly larger diameter, equal length primaries, etc.) so the the differences between $65 and $1000 headers become very small (ie, porting, polishing - most things you can fix with a dremmel) and any power improvements negligible.
regarding the cats, please show my anything that confirms that the cats on the mid pipes are more restrictive than the cats on the headers. here's a previous post by a board member regarding cell count:
"Anybody have any idea how many "cells" are in the OEM primary and secondary cats?
I've come across differing information. In the past, I've been told that the primary cats are 400 cell and the secondaries are 600. However, I tend to think that they're 400 cell all around."
so, either the cats are the same, or the cats on the midpipe (the 600 cell secondaries) are more restrictive. either way, best money and performance are on the ebay headers and leave the midpipes as-is.
Old 09-03-2011, 12:00 PM   #19
Throughout my entire experience conducting exhaust mods, I've both read and have been told by virtually every knowledgeable exhaust "tech" and "tuner" that the secondary cats on the 986 were 600 cell .
Old 09-03-2011, 02:33 PM   #20
There is a lot more to it than that......
insite
'99 Boxster
3.4L Conversion
